Speed sensitive Power Steering setup
From diagrams I found that the JZS161 Aristo had a steering ECU above the left rear wheel, which seemed like a long way from where it is needed (near the ECU and dash). In a later search I saw another diagram showing the steering ECU above the steering column.
Last night I found a reference stating that the 161 had some sort of rear steering, which explains the second unit and why it is in the back.
Located the wiring diagrams for the front steering ECU, which has 5 wires 1. power from ignition, 2. earth, 3. speed sensor input, and two wires to the solenoid on the power steering pump.
The power steering ecu is a small brown box above the right knee in the drivers position. *The box is about twice the size of a match box (or slightly bigger) so since all the required wires are in the ecu box i have put it there. The spd wire went to the old ecu and is not used on the Aristo ECU, so it is available for the power steering ECU.
I can find no reference to the IS200 having speed sensitive steering. On the high pressure line near the steering rack there is a pressure sensor whose signal went to the ECU, but that was removed as part of the conversion. The 2JZ has the power steering pump on the other side of the engine so I was able to use the high pressure line from the Aristo and manipulate it with heat to get it to be at the correct angle for the steering rack and make it shorter with an extra S since the IS200 engine bay is not as wide as the Aristo.
The reservoir and low pressure lines were easily done with a steel section run across the front (above the intercooler). Interesting that the low pressure lines will crack if you try bend them with heat but if cold they can be worked quite a bit. I started with a rather bendy section from with the car or the frontcut and when finished it was straight and perfect for the job since the ends were barbed to keep the rubber hose from coming off.
