Pretty sure the Aristo Fuel Pump ECU is located in the rear of the car so it's not likely that you have it as part of the front cut
This is relevant however...
http://wilbo666.pbworks.com/w/page/4...20COR%20Wiring
They go to the engine mounted diag connectors I believe. Why to be honest I could not detail!
Are you sure the IS200 doesn't have a separate Proportional Power Steering (PPS) ECU? i.e. JZA80 has a separate PPS ECU and the wiring simply goes via the engine loom wiring. JZZ3x has the wiring as part of the body loom side however...
I'm pretty sure it should be a case of just making sure that the existing IS200 wiring remains unchanged at the end of the day.
Do you have the part numbers for the factory items / what they are sourced from?
