Results 1 to 13 of 13
Thread: Conversion Help
    Junior Member Backyard Mechanic kugzs's Avatar
    Default Conversion Help
    im about to change my Ta22 from auto to manual.
    i have all the parts necessary.
    could someone write up a step by step guide on what i need to do.
    (Note; its a 2T and i will be putting in a T50)
    thanks alot.
    josh
    Default Re: Conversion Write Up
    doesnt need to be too detailed.
    any help would be appreciated.
    note; i will do a detailed write up with pics once ive done it
    cheers josh
    tasmania
    have you used the search button yet? have a search cuz i reckon it's been covered before
    really, all you need is the 2T-T50 bellhousing,
    the flywheel,
    pressure plate,
    clutch plate,
    slave cylinder,
    master cylinder,
    clutch thrust fork,
    thrust bearing,
    tailshaft,
    and as for the pedal, i'm not sure if you need a TA22 manual pedal box or whether they are all the same and you simply put the clutch pedal in?
    i think you'll have to change the centre console as well
    beer me!
    tasmania
    you might have fiddle with the carby or change it too, as it'll have a cable mechanism from the auto on it.
    oh, and you'll need the manual gearbox crossmember.
    beer me!
    mate i have all the parts i need, i was just hoping for someone to write up a rough guide on how to actually perform the conversion.
    ie step 1
    blah blah blah etc etc
    but thanks anyway
    1) rip out old auto box which is associated to the devil
    2) insert new gearbox with all clutch stuff assembled rightly
    3) put pedal/pedal box in and hook up all hydraulic clutch stuff
    4) sort any little problems that have popped up
    and ur done.
    all info on changing clutches or gearboxes has been covered, you just have to make it specific to your car...
    Last edited by love ke70; 15-05-2006 at 11:43 AM. Reason: why does the tab button make it post :S
    tasmania
    to make it easier, loosen the engine mounts and tilt the motor back, and use a block of wood or something to keep it there. it'll make it easier to take the auto out and put the manual in.
    beer me!
    thanks for the tip.
    even better though
    if anyone in sydney is willing to help me change from auto to manual for a case of beer and pertrol money that would be great.
    pretty please
    Just Another Part Time Grease Monkey
    Default Re: Conversion Help
    kugzs
    Don't forget to insert a spigot bearing (goes in the end of the crank shaft and supports the drive that goes into the gearbox).
    Make sure the pivot for the clutch pedal is solid since if you just rely on the thin metal it will fatigue and crack.
    Good luck
    for anybody interested, tomorrow i am putting the manual in my car.
    I will be writing up a detailed guide with pictures. If it helps someone then it will be worthwhile.
    and thanks to craig
    Tasmania
    Also make sure you use the manual flywheel bolts also as the auto flex plate bolts are shorter.Id love to give you a hand with it but im quite a few 100k's away might be a bit costly
    Cheers Brett.
    ONLY a few hundred k's.
    thats a poor excuse if ever ive heard one.
    anyways thanks for the tip. Again thanks to craig for the manual flywheel
    Tasmania
    Yeah that stretch of water gets a bit cold this time of year
    Cheers Brett.
  1. MA61 - RA65 Struts & Powersteering Arms conversion
    Last Post: 04-06-2013, 09:38 PM
  2. MA70 --> JZA70 Conversion
  3. KE20 Front drum to disc conversion guide
    By BSIDE in forum Tech and Conversions
    Last Post: 24-03-2006, 03:00 AM
  4. ST162 Conversion
    By Pure-SX in forum Tech and Conversions
    Last Post: 30-01-2006, 01:34 PM
  5. Rear Disc Conversion for FWD Cars
    By wagonist in forum FAQ
