Results 1 to 5 of 5
Thread: Anyone fitted a old T-50 extension housing to a newer T-50?
    Default Anyone fitted a old T-50 extension housing to a newer T-50?
    Having a look at where to put the gearbox in the Mallock and I reckon if I can fit the old forward gearstick position extension housing (TA-22 Celica) to the AE-86 type T-50 that will have the gearstick in the right position.
    Anyone tried it? I reckon you'd need the older selector rods as well to make it work.
    www.billzilla.org
    Toymods founding member #3
    Dec 2011
    ATL GA USA
    Default Re: Anyone fitted a old T-50 extension housing to a newer T-50?
    if you talking about the bellhousing, yes it is posible but the old bellhousing need to be machined wider on the front bearing slot!
    Basher Grease Monkey
    Feb 2007
    Your reckoning is right,just swap the shift rods over.
    Scott
    coronacoronacoronacorona
    Quote Originally Posted by sbfoot View Post
    Scott
    Thanks - I asked on PF and got the same answer so it seems like an easy conversion. I'll have to do it twice as the T-50 in the Starlet (when I get to it ...) needs the same treatment to make the gearstick come out the original hole in the gearbox tunnel.
    www.billzilla.org
    Dec 2011
    ATL GA USA
    ooops i misunderstood, weird!
  1. r154 extension housing
    By YGO 08 in forum Tech and Conversions
    Last Post: 29-09-2011, 04:43 PM
  2. Aristo 2jzgte auto - extension housing swap over
    By wrench in forum Tech and Conversions
    Last Post: 31-05-2010, 07:16 PM
  3. 1jz extension housing same as mx83
    By jeffro in forum Tech and Conversions
    Last Post: 29-05-2007, 09:34 PM
