I'm not familiar with the DLI boxes, but does it require a timing advance signal? I know with the stock VAST ignition setup on the Bigport 4AGE, if you disconnect the IGt signal from the ECU to the VAST igniter, it will run (the dizzy is wired directly to the igniter like EDIS) but it gets limited at 10 degrees advance. It really kills the ability to rev when your stuck at 10 degrees and will make the car drive like ass, but it's enough you can limp around.
