Page 4 of 27 FirstFirst ... 2345614 ... LastLast
Results 46 to 60 of 405
Thread: Wakefield Park Track Day - Friday 22nd of June!!
  1. #46
    Jul 2007
    Default Re: Wakefield Park Track Day - Friday 22nd of June!!
    Sweet - and you've got four cars to choose from now, so you should be running something.
    hopefully an adub otherwise le sil80
  2. #47
    Quote Originally Posted by RONA View Post
    Engine builder was in Ipswich, they have a depot there so was kind of out of convienience.
    TerryO?
    How's everyone else going? 4 weeks out, need to get these spots confirmed.
    Toymods Club Member
  3. #48
    北海度
    Will confirm when I arrange a tow car. Got the MS65 but not sure if it will be up to it.
  4. #49
    TerryO?
    Yup, motor looks awesome.
    PS Things looking up, engine/driveline back in car and turbo setup being trial fitted ready to send off for Fabrication. One hurdle is the gate I supplied is too big physically so will probably have to swap to a nice compact TiAL unit instead. Meh it's only money haha.
    If in doubt power out
  5. #50
    I've been having troubles finding an uprated clutch. Asked 3 different shops to find me something.
    I can understand people not really modifying an Elantra, but to have someone tell me I have to resort to a full custom built clutch is a bit ridiculous (especially when 5 mins Googling comes up with 2 Exedy versions). It's only an NA <1000kg car, not a twin turbo V8 or something
    Can people give me some honest opinions about having a button clutch? I've never had one before, so trying to work out the pros/cons for trackwork/motorkhanas (including dirt)/possibly hillclimb.
    I've got a dirt motorkhana coming up on 3 June, so should be ready for Wakefield
  6. #51
    Unless the engine is significantly modified what's wrong with a standard one? Or slightly uprated exedy 'heavy duty' one? Bit more pressure should be all you need.
    Toymods Club Member
  7. #52
    Thanks Garth. Came to a bit of that conclusion myself.
    The LSD is installed with a stronger gearbox but not yet ready for the larger engine to go in yet. There is a possiblity of forced induction at some point. Even then, the limit's prob going to be around 150kW at the flywheel. So standard's not good enough, but the button clutch would be overkill.
    I couldn't get drvieshafts as thick as those which match the gearbox, but I've got a 250kg weight advantage over that car, plus significantly shorter shafts, so that's ok.
    Just with the low number of kms being done now, the clutch is highly unlikely to get worn out so didn't really want to be throwing money at it unnecessarily.
    Now I've just got to figure out how to remove the thrust bearing from the pressure plate (pull clutch) so that pressure plate can be reused...
  8. #53
    Junior Member Domestic Engineer 1jz68u's Avatar
    ok so i made a bet with an Audi RS4, BMW M3 and an ISF that i would beat them, so i may be at this day just for practice. i will ask them to come to this day but hopefully i get some more time to practice before i lose my dignity.
    Glenn
    Current Ride http://www.toymods.net/forums/showthread.php?t=41123
    Previous 3SGTE ST162, 1JZ Cressida 215RWKW-ET 13.318, Celsior, XT forester, 3SGE KE70.
    Quote Originally Posted by NME308 View Post
    You do of course realize forgiveness is easier to gain than permission right???
    Cheers, Jason
  9. #54
    Just tell them all to avoid the mobile orange chicane...
  10. #55
    Quote Originally Posted by 1jz68u View Post
    If you lose go double or nothing on my wagon chopping them, they'll be sure to bite haha. I'll keep the bonnet closed and we'll tell them it's a stocker with suspension and brakes.
  11. #56
    Well that's some confident talk Rona.
    Toymods Club Member
  12. #57
    New gearbox is in, just need to bleed the clutch & fill all the fluids tomorrow to make sure it works (wasn't as hard as I thought to fit the clutch fork to a previously used pull clutch pressure plate).
    Then I'll be able to confirm my attendance.
  13. #58
    loves hi RPMS Backyard Mechanic
    still a maybe for the moment garth. after talking to you about it on friday night i am very keen, but would really like to get the stack dash in first so i can see if somethings about to explode before it explodes...
    and if i can swing it, the 4.77 in the rear
    N/A for life...
  14. #59
    Jul 2007
    this makes me even sadder about not having the adub ready
    edit; money coming your way garth. i need me another trackday even if it is only in the nissaids...
  15. #60
    Hehe deadline is looking doable
  1. Wakefield Park Track Day - Friday June 19th!!
    Last Post: 14-10-2009, 12:06 PM
  2. Wakefield Park Track Day - Friday 20th of June!
    Last Post: 14-08-2008, 10:59 AM
  3. Replies: 191
    Last Post: 07-06-2007, 10:33 AM
  4. Wakefield Park Track Day Friday 9th March
    Last Post: 02-04-2007, 04:11 PM
