Results 1 to 5 of 5
Thread: Replacement 2tgeu tappets/lifters needed
    Aug 2009
    Default Replacement 2tgeu tappets/lifters needed
    Does anybody know a replacement tappet for 2tgeu, or late, 2tg out of later vehicle i.e more easily available?
    Amayama has 6 only in OD I need. Any about $86 each.
    My originals are pitted badly around perimiter and marked on top. Cams will be reground to 292 duration.
    VAASA / FINLAND
    Default Re: Replacement 2tgeu tappets/lifters needed
    Some peugeot 405 lifters will work, some are tight some with just good clearance, they are a little higher, so work only with re grinded cams.
    Check clearence !! I have test and to some heads they are quite tight.
    I think its easy to find good used OEM lifters
    - Celica TA-22 -74 2T-G Turbo
    - IQ 1.0 -09
    - Lexus IS250 -06
    Jan 2012
    Finland
    18R-G/2T-G/3T-GTE buckets are all interchangeable so there should not be shortage of used ones (considering how many heads are scrapped by overrewwing/wrong installation...)
    Sure,they are matched to the head bores from factory but I have yet to see a bucket that don't fit!
    Junior Member Grease Monkey styler's Avatar
    Jun 2006
    Kameari has these aftermarket but expensive
    Nov 2007
    I have a dead 18RGU head if you need a bucket or two to replace missing ones. I also have a heap of shims so maybe able to help out when it comes time to set the gaps. I say maybe as I changed my cams on Monday to a different set and even with all the shims I have still had to order 8 new ones.
    Glen
    RA28 (18RG)Members Ride
    RA40 (3TGTE)
    RA40 (18RC)
    SXA11R Rav4 Cruiser
    ACA33R Rav4 Cruiser
  1. Noisey Tappets
    By 1975ToyotaCrown in forum Tech and Conversions
    Last Post: 14-07-2008, 01:02 AM
  2. Just adjusted tappets.. Still rattling?
    By pisso001 in forum Tech and Conversions
    Last Post: 19-08-2007, 10:09 PM
  3. EFI setup help needed for my 2TGEU
    By minxgirl in forum Tech and Conversions
    Last Post: 26-01-2007, 10:39 AM
  4. AE80 tappets
    By GMSkitz in forum Tech and Conversions
    Last Post: 20-06-2006, 11:09 AM
