Results 1 to 5 of 5
Thread: 1JZ Cressida Losing Transmission oil
    Jul 2011
    Default 1JZ Cressida Losing Transmission oil
    Hi All,
    Have been recently filling the transmission fluid in the auto quite frequently. There is trans oil on floor when its parked, and from a quick look, looks like its sprayed around under the car as well (around tailshaft area).
    I'm currently away so i havent had it up to have a proper look yet. Just wanted input to see if its a common occurence and where it could be leaking from?
    Did see oil drip from one of the pipes (i think its cooler pipe from tran to rad) but didnt look exessive. (are any of the gearbox lines high pressure?)
    Car Details:
    Triptek 1jz stock conversion mx83 cress. No mods all stock. Drives smooth no noises no nothing..
    I believe its from chaser? original gearbox from chaser as well i think
    Jan 2011
    Default Re: 1JZ Cressida Losing Transmission oil
    is this the two toned one in ocean reef? this was my old one !
    1992 X83 Grande + 2JZGTE (Sequential)
    Jan 2011
    did you end up sorting it out? i heard the dipstick was changed in japan and it was over filled with transmission fluid due to the incorrect reading on the dipstick?
    May 2007
    check the output shaft seal on the gearbox...
    especially if its been overfilled with fluid
    SPARCO|TEIN|SUPERPRO|SELBYS SWAY BARS|PERFORMANCE PARTS AND APPAREL LIKE US ON FACEBOOK!
    Jul 2011
    Yep sorted. Dipstick was wrong... I dono about two tone, i guess its white/silver... yeah ocean reef
  1. 3sgte losing an abundance of oil
    By punkture in forum Tech and Conversions
    Last Post: 19-07-2011, 02:51 PM
  2. Losing Coolant
    By Razor in forum Tech and Conversions
    Last Post: 23-03-2009, 01:57 PM
  3. Car losing traction in wet a lot
    By Z2TT in forum Tech and Conversions
    Last Post: 29-09-2008, 11:27 PM
  4. ke70 losing power under load...
    By Munki in forum Tech and Conversions
    Last Post: 06-05-2006, 08:56 AM
