Results 1 to 4 of 4
Thread: JZA70 ECU Question
    Sep 2011
    Default JZA70 ECU Question
    Hey guys, I've got a JZA70 and the ECU has some corrosion and the board is stuffed. As A70 ECU's are like hens teeth, I heard that a JZX81 might be compatable. Has anyone heard the theory and do you have one or know of someone who does ?? Cheers. Pete
    May 2010
    Moscow
    Default Re: JZA70 ECU Question
    Hard to answer without wiring diagrams, but I can supply you with one for JZX81.
    I believe JZX80 ECU will work as well, but probably with some minor modifications to loom.
    JZX81 and JZA70 share the same ECU pinouts so you will be able to swap ECUs, only thing is that JZX81 will always be auto (unless its been converted to manual, though you can run a manual with the auto ECU).
    For reference, JZZ30 and JZX90 share the same ECU pinouts but are different to the two above so not interchangeable with those.
    Sep 2011
    Cool .. thanks Guys .. just need to find an JZX81 ecu now and yes it is an auto .. greatly appreciated
  1. Twin C12a question from jza70 half cut
    By zork in forum Tech and Conversions
    Last Post: 18-01-2007, 04:14 PM
  2. stupid 3tgte question(sorry is a real noob question)
    By lilcrash in forum Tech and Conversions
    Last Post: 20-03-2006, 07:13 AM
  3. JZA70 R Fuel Gauge Question
    By boris in forum Tech and Conversions
    Last Post: 17-01-2006, 12:03 PM
