Mate if your going to replace the guide, you might have trouble getting the valve to seat properly. You might be ok, but a lot of the time you won't, and it probably won't be damaged, maybe just worn. Did I read somewhere that you were thinking about reusing the head gasket? DON'T...
You could try a leak down test with the cams out to eliminate variables. See where your comp is going before getting too involved.
Does the bucket fall under its own weight, or do you add pressure?
I got a spare valve that had been recut but never ran, so I lapped it in & put the head back on & motor running in under 4 hours. Happy camper! Also feels heaps better with the new LSD I only just got to try out cuz of this valve problem. Thanks to everyone for all the advice on this thread, it helped big mobs!
