Results 1 to 7 of 7
Thread: RA23 & TA22 rears half the same?
    Jun 2007
    Default RA23 & TA22 rears half the same?
    Hey All,
    Sorry if this has been asked before/is common knowledge, but I'm wondering if body-wise (panel shape, boot lid, lights, bumpers, mounts for diff & suspension, fuel tank etc) the back half of the TA22 is the same as the RA23/TA23? Long story short I'm looking for a back half of Celica to repair my RA23 as it was hit by a dickhead in a commonwhore from behind. I'm hoping that the TA22 is the same cos it'll make it a lot easier to find a rolling shell.
    Ben
    Eltham vic
    Default Re: RA23 & TA22 rears half the same?
    hi ben
    get in touch with PAC
    he has a complete 23 shell he may sell you cheap
    ian
    Jan 2011
    Everything I've read says yes, but I'm not sure about 22s with the flat tail lights.
    You can always try Dave at sleeka spares, he's helped a couple of times with knowledge of the interchangeability of mechanicals. Might able to help on panel stuff.
    Early TA22 Celica has fuel tank in floor, so skip that one. The later TA22's have essentially the same body section as the RA23, however, there are some differences, for one, the fuel tank mountings are different, as the RA has a larger tank. Spring, shock and the other suspension mounts are the same, with the possible exception of the panhard rod mount.
    The most noticeable external difference can be the rear geard arch shape. I have seen an early (1972) Celica that had the rear qtrs from a later model stitched on. Looked funny because the wheel arches are rounde edge on the early amd square edged on the later.
    Boot lids are the same on all this series coupes, bumpers are different only in the mount bracket and attaching holes on the car.
    cheers Chuck
    MS51Crown Coupe,
    May 2011
    i've got a rear right quarter that might help.
    http://www.toymods.org.au/forums/int...ls-galore.html
    GOT: Suzuki SV650 with lots of mods - Almost stock XC falcon ute with 351 and gas
    Building: TA22 with SR20DET
    Nothing but a Backyard Mechanic caam's Avatar
    Apr 2010
    Early 22's (Flat lights and Floor fuel tank) are very very different,
    But later models, 73/74/75 are almost identical minus the fuel tank and mounts for the tank
    Bumpers and tail lights are all interchangeable
    Cam
    Jun 2007
    Hey,
    Thanks for all the replies fellas! I had a feeling that the panel shape around the wheel arches was different but couldn't remember for sure. That shell from Pac is looking good at this point, Cheers Ian! Thanks again for your help everyone =D
    Ben
  1. TA22 Ignition half dodgy
    By Oddyssey in forum Tech and Conversions
    Last Post: 15-01-2007, 11:38 AM
