I will say that it is most centres that break under extreme conditions.Normally its the sun gears that break most of the time.But axles do break once in a while also.
I had a 1966 RT 40 Corona 1600S which I had put a 18RG into and for memory it ran a S series diff 4.11:1 ratio.This car was no sloutch when it came to grunt so not long after the conversion was done I decided to see how good the diff was.Popped the clutch at about 5000-6000rpm and bang broke an axle.The diff was fine but axle was broken inside the sun gears and would not budge.Never used that diff again.And the motor that was in it prior to the RG was a fairly well worked 1600 and that rear end took alot of punishment with the 1600 but the with the RG it lasted about a week.And the 1600 motor was put into another RT 40 1600S I had and I also broke an axle in this car.So yes axles will break.
Cheers Brett.
Oman
