You definitely can, but you will need to support the Gearbox after you have removed the motor and the top two bolts are a PITA to undo/tighten.
Can I remove the motor without the gearbox?
1974 Celica TA22
2TG Motor
5 speed box
Cheers Richard
Yeah piece of piss, just make sure you take the Gb cross member off and if you have one of those balance bar thingos you can put on the engine hoist to lean the engine on an angle it will be a heap easier too.
-Just Alloy Radiators-
www.alloyradiators.com.au
its easier to remove engine and gearbox together.... MUUUUCH easier.
In my RA28, i had it down to a 90 minute job from drive into garage to engine/gearbox out of car and separated (18RG + W58 box)
Pulling the motor without the gearbox is easy as,
Top bolts are a bitch to get at but a couple of long extensions and a knuckle joint normally do the job, can have the motor out in a little over an hour
