Results 1 to 6 of 6
Thread: microtech cas wiring (just to solve a debate)
    Default microtech cas wiring (just to solve a debate)
    cant find the answer anywhere lol so here it goes
    if i wire in a microtech etc into my 3rzfe , it runs a cas , and coil packs from factory, when i wire it in, do i need resistors etc to get the right voltage for the cas to fire? or what?... and do i need to know trigger angle or will it work it out its self?
    i dont fully understand the electronic side of ecu's so i may sound stupid haha, just know how to wire one in not what makes it tick..
    thanks
    Default Re: microtech cas wiring (just to solve a debate)
    is the CAS a reluctor of hall effect? reluctor generates small AC signal, hall effect give a 5V square wave.. neither should need resistors? (as long as you have a 5V power supply for the hall)
    you probably need to know the angle... otherwise what do you tell the ECU?
    south australia
    the microtech ecu comes with a seperate CAS loom. its labeled and everything. i know this cause i am working on one as we speak.
    keyboard in one hand and wire strippers in the other....haha
    in the microtech book, it shows you exactly which wire goes to which one on the CAS. then its just a matter of joining them (properly).
    then i guess you configure the pickup type once you have the laptop plugged in. microtech usually provides a base map so you can start the engine.
    Quote Originally Posted by slide86
    in the microtech book, it shows you exactly which wire goes to which one on the CAS. then its just a matter of doing the opposite and joining them (properly).
    Fixed for a 1jz wiring diagram anyway
    QUICKEST 1JZ'S IN OZ
    Forum Sponsor Grease Monkey
    you can't configure any triggering angles with a microtech thats why you order them for specific engines and wait/pay to have them changed if you put them on different engines.
    Nissan ones have a few options but you don't change them.
    The microtech is wired for the engine as well ie powered sensors like nissan ones get 12v and ground from the microtech CAS wires, whereas a microtech configured for variable reluctors has no power wires in the CAS loom they are all signals and grounds
    never heard of using resistors for CAS on any ecu for that matter can't think why you would need them
    u use reistors on the ms ecu, to change values / volts etc
  1. Microtech wiring help: VVT and a/c
    By bobob in forum Tech and Conversions
    Last Post: 01-11-2018, 12:58 PM
  2. Microleb wiring assistance on 1JZ!!!11oneone!!11(LTX-12)
    Last Post: 23-05-2006, 11:27 AM
  3. understanding 4agze wiring diagram-HELP-
    By slide86 in forum Tech and Conversions
    Last Post: 18-04-2006, 06:09 PM
