Results 1 to 5 of 5
Thread: 2JZGE and 5 Speed Autos - What Cars Were Factory Fitted With Them?
    Perth WA
    Default 2JZGE and 5 Speed Autos - What Cars Were Factory Fitted With Them?
    Only concerned with 2JZGE's and 30-50LE 5 speed auto transmissions - what cars were factory fitted with them and if possible what were the part numbers for both the ECU, and the wiring loom? I believe 1996 on Aristo's were such, who knows of anyo thers?
    Junior Member Grease Monkey MacroP's Avatar
    Default Re: 2JZGE and 5 Speed Autos - What Cars Were Factory Fitted With Them?
    Hey Clint,
    When I get home later I'll check my EPC disc. For starters, do have the part number from that 5 speed you have? I need the number off the side plate at the back of the box. I could then trace everything from there. Cheers.
    vic
    you will have fun with the c bus link in the lexus i would imagine . and if the key computer isnt enough of a pita
    Perth WA
    spill your guts Dave - I want more info please?
    Marco, the model designation is the one I've given in the first post, i assume there is a slight difference in box designations, and workshop designations, as I've never seen (for example) an A340 "box, but have plenty of 30-40LE boxes, like the one you got from me the other week (which I'm glad to hear is going brilliantly - made it a cheap fix hey?!).
    Clint there should be another number on the tranny where it reads the 30-50LE bit. The Toyota part number (35000-xxxxx)should be there too. I can trace it's origin with this number.
    I've found one so far from a 2JZGE A350E powered Crown Majesta JZS155. They are dated 95-97.
    Engine ECU # 89661-3A120
    Engine wiring loom 82121-3A160 or 82121-3A170
    Transmission wiring loom 82125-30311
    Also Crown Majesta JZS143 also has the same setup.
    ECU # 89661-30520 91-93, 89661-30770 93-95.
    Engine wiring 82121-30770. There are 12 revisions of this loom over 2-3 years.
    Transmission loom # 82125-30310 + many more revisions too.
