gah, auto spell on android fails.
Ok ive been reading all morning on my phone.
ive come actos this.
'A basic overview of the system goes like this. The camshaft sensor or crankshaft sensor sends a signal to the engine control computer. The engine control computer generates and IGT or trigger signal based on these two inputs. This IGT signal is sent to the igniter. The igniter in turn fires the ignition coil at the appropriate time. When the coil fires it releases secondary energy which triggers the igniter to send a confirmation signal or IGF signal back to the computer so the computer knows that the ignition coil did in fact function. When this code is set it means the computer is not recognizing that the ignition coil has fired so it shuts injectors down so that the system does not flood out'
Ok so i could have faulty wiring on the crank angle sensor side of things hence when i wiggle it i can get it to stop.
Might see if i can swap the cas tonight as i have a spare.
fingures crosssed
or if any one else has an idea.
I also noticed this
Igniter Pinout, anyone have the missing info from this pic? - HybridZ
this tells me the ignighter is internally grounded on a pin,
when i swapped igniters i didnt bolt it up and it would not run.
can any one confirm that the igniter does not deed ground?
