Results 1 to 6 of 6
Thread: Need tailshaft conversion 1uz auto (A340?) to hilux diff
    Feb 2011
    sa
    Default Need tailshaft conversion 1uz auto (A340?) to hilux diff
    Hi
    I have a 1uzV8 and auto in my 34 roadster it has an early hilux diff, the auto has a three point flange on the back which I assume was used in the Celsior with an independant rear end.
    I have heard of an alloy flange for a Landcruiser tailshaft which could have the same mounting holes and then I use a slipyoke from a landcruiser in front and the four bolt flange off the Hilux in back, can someone confirm the flange and suggest a supplier in SA?Cheers
    Rob
    Jan 2008
    queensland
    Default Re: Need tailshaft conversion 1uz auto (A340?) to hilux diff
    i have just had a tailshaft made just like this.
    approach a tailshaft maker/supplier and ask them to do it
    i used driveline services in acacia ridge brisbane.
    Driveline Services Australia | Driveline Services
    neil
    2009 aurion
    Purple 2000 Hilux - 1UZ
    Aug 2011
    adelaide tailshaft service - dry creek - (08) 8349 8024
    Quote Originally Posted by chuckles34 View Post
    Hi
    Rob
    Or you could attach an output flange off a Hilux A340H automatic transmission with a suitable oil seal and use Hilux driveshaft parts
    looks like this
    Jealousy is a curse
    Feb 2011
    sa
    Which model/year Hilux has that flange - if it has the same position for the mount it seems the best way for me to go I could use the shifter from one as well . A guide price for both would be nice as I am in uncharted territory here, I have played with SBCs Holden, Desoto and Ford V8s but these 1UZ gems are new to me.
    Rob
    Kinda funny being tagged as a first year apprentice since I taught Automotive at TAFE until 2001!
    The housing and shaft pictured are from a A340E . A340Hs were in 4Runner autos . NOT SURFS. Forget about the shifter from one although a shifter from a Hilux auto 2wd may work for you.
    Jealousy is a curse
  1. Hilux 3RZ 2.7 - Auto to Manual Conversion HELP?
    By FD1 in forum Tech and Conversions
    Last Post: 18-09-2011, 01:07 PM
  2. Single Piece Tailshaft in ra23 with Hilux Diff
    Last Post: 28-09-2009, 10:17 AM
  3. Hilux Diff Conversion
    By Hokey in forum Tech and Conversions
    Last Post: 03-03-2008, 11:42 AM
