Results 1 to 4 of 4
Thread: 1G-GZE camshaft specifications
    Jan 2010
    Northants U.K.
    Default 1G-GZE camshaft specifications
    I have just about finished building an Eaton M112 supercharger conversion for my 2JZA80-GE and plan to use the stock exhaust cam and either the GE or GTE inlet cam.
    I am looking for 1G-GZE camshaft specifications to help choose between them and work out ball park settings using adjustable cam gears.
    Does anyone have 1G-GZE OE cam specs please.
    Default Re: 1G-GZE camshaft specifications
    That looks very nice there, I look forward to seeing some results for it.
    I have the Japanese 1G-GZE manual but unfortunately I dont know any Japanese so I have also posted up the English 2GR-FE information as I would suspect they would use the same format and you can work out the specs.
    1G-GZE
    2GR-FE
    Jan 2010
    Northants U.K.
    The figures I wanted to see are shown in English.
    Thank you very much.
    Jan 2010
    Northants U.K.
    I will be using a GE exhaust cam and choose between GE or GTE inlet cam, I suspect the GE is the better?
    I have adjustable camshaft gears and am informed that +1° inlet -3° exhaust are 'ball park' settings for stock cams on both 2JZA80-GE and GTE.
    Is there a camshaft Guru here who could advise which inlet cam to choose and supercharger ball-park settings please.
    Exhaust cam. (common)
    Lobe separation 114° TDC
    Exhaust Duration 233°
    Exhaust Camshaft lift 8.4mm
    Exhaust valve diameter 29mm
    Exhaust Valve timing - Opening 52° BBDC
    Exhaust Valve timing - Closing 4° ATDC
    Inlet cam choices
    GE 10:1
    Lobe separation 114.5° TDC
    Intake Duration 235°
    Intake Camshaft lift 8.3mm
    inlet valve diameter 33.5mm
    Intake Valve timing - Opening 3° BTDC
    Intake Valve timing - Closing 52° ABDC
    J spec GTE 8.5:1
    Lobe separation 113.5° TDC
    Intake Duration 224°
    Intake Camshaft lift 7.88mm
    Inlet valve diameter 33.5mm
    Intake Valve timing - Closing 50° ABDC
    Export spec GTE 8.5:1
    Intake Duration 233°
    Intake Camshaft lift 8.25mm
    For reference;
    1G-GZE 8:1 camshaft spec
    Lobe separation 113° TDC
    Exhaust Duration 240°
    Exhaust Valve timing - Opening 53° BBDC
    Exhaust Valve timing - Closing 7° ATDC
    Lobe separation 112° TDC
    Intake Duration 228°
    Intake Valve timing - Opening 2° BTDC
    Intake Valve timing - Closing 46° ABDC
  1. T, 2T, 2T-B, 2T-C & 2T-G Specifications & Diagrams
    Last Post: 29-02-2016, 12:30 PM
  2. Brake Specifications...
    By Rolla Boy in forum Tech and Conversions
    Last Post: 10-07-2007, 09:23 PM
  3. Crown rim/tyre specifications
    Last Post: 29-07-2006, 01:39 AM
  4. RA40 Specifications
    By mike1980ra40 in forum Tech and Conversions
    Last Post: 28-06-2006, 04:36 PM
