Results 1 to 2 of 2
Thread: 4age help!
    Oct 2017
    Raumati Beach
    Default 4age help!
    Engine is a blacktop 20v, burning oil under acceleration and it stinks!! Did a compression test, noticed a bit of oil in cylinder #2 but I think that's just because the valve cover has no gasket just that silicone gasket stuff. Anyway, did a compression test got 210 across all cylinders, but then did a wet compression test and cylinder #2 went off the clock!! So confused. Need help on what to do as I'm a student and haven't got money for a mechanic. Is it head gasket or what?
    Dec 2008
    Wellington, NZ
    Smile Re: 4age help!
    If you got 210psi in all four cylinders dry, that is a good result. Providing you only put a teaspoonfull of oil down the plug hole, you should have got near enough the same result... perhaps a few psi more. There is no reason for one cylinder to go way high on the wet test unless it was way low on the dry test.
    Suggest you retest
    Cheers... jondee86
  1. MicroTech - 4AGE, 4AGZE and 4AGE-20V factory EFI configurations
    By hks7mgt in forum Tech and Conversions
    Last Post: 16-11-2008, 08:08 AM
  2. Auto 4AGE Loom, Manual 4AGE, PROBLEM!
    By prizedbnx in forum Tech and Conversions
    Last Post: 18-04-2008, 04:03 PM
  3. 4AC AE86 conveted to 4AGE, 4AGZE and 4AGE 20V
    By wombat in forum Engine & Driveline Conversions
    Last Post: 18-04-2007, 09:43 PM
  4. 4AGE 86KW TVIS V 100KW 4AGE + Shocks
    By GeeEss in forum Tech and Conversions
    Last Post: 17-01-2007, 08:51 PM
  5. Shims for Cam bucket?! Are JDM 4AGE same as AUDM 4AGE?????
    By beige_bandit in forum Tech and Conversions
    Last Post: 19-01-2006, 11:08 AM
