Results 16 to 18 of 18
Thread: LS1 coils on 1JZ
    Nov 2011
    Default Re: LS1 coils on 1JZ
    haltechs and toyotas do not go together to well
    i know the older ones didnt like mag sensors so u had to run
    reluctor interface
    new sport and sprints might be better now they are totally new ecu
    anyway get a bucket fill ti with water and throw the e8 in
    its nearly as bad as the good old haltech f7
    have u hooked up a laptop to see if yr getting correct rpm
    also try swapping the sensor wires over maybe u have sensor hooked up backwards
    as in neg to pos and pos to neg on the sensor
    if u do want to persist with it maybe try a reluctor interface or atleast speak to haltech
    but be prepared to waste alot of time on and off fiddling with stuff
    but most tuners u speak to say same thing bout old haltechs and toyota reluctor sensors
    Apr 2010
    queensland
    i just used 2nz (toyota yaris/ echo) coils in my 2jz. $20 each built in ignitor, coil over plug and i made 523 with 23psi and no spark blowout what so ever. i have heard of other guys running 25-30 with them. worth it to me unless your chasing big hp and big psi?
    DumbAss is correct.
    I fought for ages with the 1g-gte and the Haltech IG5. In the end I had a hall effect switch knocked up to go in the dizzy, 6 teeth and a home tooth, then it worked a treat!!!
    So, basically your options are:
    1) E8, 1uz standard magnetic triggers, Haltech Reluctor Adapter. This will turn the Magnetic triggers into Hall effect triggers which will make it around the engine bay nicely, however they are still prone to noise. Can be setup - I did it once upon a time.
    2) E8, custom hall effect triggers. I had this running on my 1uz with the IG5 for a while, worked fine. I can show you photos of my setup, and I can get the parts made up for you from the guys who made them up for me. They are very fancy bits of kit, and a bit on the pricey side but absolutely f'ing bullet proof.
    3) Ditch the E8 and get a Sprint XXX. I'm using a Sprint 500, and it picked up the magnetic sensors no problem at all. Infact did it so well that I had it turned onto Hall effect triggers rather than magnetic and it STILL worked!. I would highly recommend the new range of Haltech ECU's, they are very good. I happen to have running on mine now, the Sprint 500, with my aftermarket custom hall effect triggers and it's infallible.
    That's the way I see your options.
    Prices roughly:
    Sprint 500 ~ $1k + some sensors (sensors are usually cheap)
    Aftermarket Hall Effect Switches - $500ish
    Relucator Adapter - $200 and a WORLD of headaches.
    Facebook | LinkedIn
  1. 2jz coils onto a 20V
    Last Post: 24-01-2007, 03:21 PM
