I would fix the motor you have in there, firstly why do you have to replace the cat convertor,A/F sensor and o2 sensor all at the same time?
Honestly get someone who knows what they are doing to diagnose the issue correctly, it just sounds like they are guessing.
Most of the time when A/f sensor and o2 sensor codes come up it is the sensors telling the ecu that they are stuck on full rich or lean, so the sensors are actually working correctly and replacing them will do nothing.
Does the engine run rough or missfire or burning oil?
The cause of the codes could be something simple like blocked/leaking injectors,dirty maf sensor, or exhaust leakage which will cause those codes to come up.
Has the check light just come on or has it been on a while?
I think you will find they run a r151 box too
