Results 1 to 5 of 5
Thread: help, wiring an afc up to a gen1 3sgte
    cruisin in a z30 Automotive Encyclopaedia -=DV=-'s Avatar
    Default help, wiring an afc up to a gen1 3sgte
    ay fellas, ive got the first gen of an afc to play with and try to sort out the running rich issues, anyway its the origional variable resistor with just one knob. into the ecu there are 2 wires from the afm, one labled VC and one labled VS on the pinout, which one do i hooke the afc into? cheers
    Default Re: help, wiring an afc up to a gen1 3sgte
    You use the VS connection. It is the resistive value associated with the flap opening.
    Kind Regards,
    Kurt.
    1998 ER34 ニッサン スカイラインGT- T
    thanks mate, +rep
    just a side note, and you probably know it anyways
    it is possible that when you lean out the fuel that your ignition could advance...on a turbo motor this = teh suck! so be careful with it!
    27.90s @ Esses Hillclimb
    dont worry mate, i plan to be very careful with it, i just want to tune a little bit of the stock over richness out of it...thanks for the heads up though
  1. Microleb wiring assistance on 1JZ!!!11oneone!!11(LTX-12)
    Last Post: 23-05-2006, 12:27 PM
  2. To 3sgte or not to 3sgte
    By General_Bupkiss in forum Tech and Conversions
    Last Post: 23-03-2006, 05:23 PM
  3. 3sgte and 4agze standard weights?
    By Taxi>Maxi in forum Tech and Conversions
    Last Post: 20-03-2006, 07:55 AM
