2JZ + standard auto, how many spacers on the flexplate?
Ive been having drama's with putting a standard a340 out of an aristo behind a 2jz in a cressida.
everytime i put the gearbox on it locks up after a few short turns. There is a spacer after the flexplate, should there be one before it aswell?
Re: 2JZ + standard auto, how many spacers on the flexplate?
What locks up ? Have you got the torque converter properly aligned & sitting in its drive tangs into the Auto ..
torque converter has to lock into 2 splines and the oil pump drive
so u need to get it to click 3 times
so what is box from. 2 j motor and aristo 1 j box?
what do u mean turns
u should be able to slide bell housing till it touches motor
and still be able to spin converter freely by hand
if bell housing needs to be tightened by bolts then something is wrong
and don't tighten the bolts up otherwise u will bend flew plate
I've seen this afew times
there is a thick spacer on the crank before the flexplate goes on then the flexplate then the thin washer/spacer.
thats what i thought, suspicion confirmed thanks 2jz hilux
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
