There are basically 2 main ways globes are held in.
If the plug goes on the back in the same direction the globe is in, then there is normally a little wire clip you need to press in and push to the side, then the globe should come out.
If the plug goes in at right angles to the direction of the globe, then you normally twist the globe about 1/8th of a turn, and it should come out.
