MA61 brake upgrades have been done to death on this forum. If you have MA61 struts the world is your oyster - all you need to do is SEARCH and you'll find scads of info.
ok i have a ke 70 with a 20v in it, i need beter brakes and fnt susp setup so i got some ma61 struts, i have been told that these have a much more common calliper mount hole spacing and that you can use hilux 4 pot callipers and volvo or magna discs or something... if anyone can tell me how they did it and what parts from what model car i will need that would be greatly appreciated,
cheers tim
Norbie!
www.norbie.net
especially worthwhile would be to search for ma61 and skyline (r32/z32/r33) calipers and discs
Indeed the skyline/300zx brake upgrade is the easiest and quite possibly the cheapest.
And in a 900kg corolla, you will stop so fast that you will need a G suit...
Hydra
JZA61 Celica XX
Actually now you mention it, one of those big brake upgrades seems like massive overkill for a 900kg car with a NA 1.6L engine. Methinks the MA61 brakes with good pads and rotors will be more than adequate, not to mention a whole lot cheaper.
Norbie!
www.norbie.net
thanks heaps for the feedback guys... its gonna be a pretty wild na 20v, do u really think ma61 brakes will sufice... the only reason i am upgrading is because of cooling issues... i lose brakes after on hard stop with my origional ones but they do pull up pretty firm when there not too hot, maybe just the ma61 ones with slotted rotors and decent pads?
also guys if someone could help with where i might source a coilover conversion kit for these struts or a similar alternative?
Correct and one of my mates (with an AE86) already has dibs on my stockers and struts when I do my upgrade. Its a cheap and adequate upgrade for them. Hell they aren't too bad on the supra, they stop quick enough its just hey fade rather quickly, with a 400kg lighter car though they'd be plenty.Originally Posted by Norbie
If in doubt power out
Your original brakes have solid rotors, MA61's have ventilated rotors, and that's what will make all the difference. With good pads you'd be struggling to acheive brake fade with a setup like this, even with a "wild" 4A.Originally Posted by ae71 kid
Norbie!
www.norbie.net
yeh as said above i've got xa6x calipers and discs on the front and it pulls up nicely decent set of pads and you'll be set
