Results 1 to 12 of 12
Thread: 2JZ auto box/tailsharft setup
    Default 2JZ auto box/tailsharft setup
    Hey peeps, trying to get this 2jz Cressida auto conversion finished off and I need some tailshaft questions awnsered. Mainly I'm asking about the rubber donut thing that sits between the box and the first part of the tailshaft. I'm just wondering how necessary it is as it's quite tall and comes pretty close to the tunnel and I'm worried about it hitting under hard acceleration or a good launch.
    RA23 1JZ VVTi 373hp - SOLD
    12.4 @ 110mph
    THE EVOROLLA 262.9hp - SOLD
    May 2007
    Default Re: 2JZ auto box/tailsharft setup
    you must have the aristo style auto...
    the jza80 style output has a 4 bolt flange and it is much smaller...
    not sure if you can find them easy enough...
    will require the output shaft to be cut down slightly as its a little long (usually sits inside rubber donut)
    can dig up pics if you want to see what im talking about
    yeah man that would be good
    this is the back of the box
    This is the tailshaft arrangement
    Id like if anyone could shed some light on why toyota have done it this way and not the way its done like every other A340 setup where the yoke goes straight into the back of the box?
    Also is there any benifit to having a 2 piece tailshaft? I would prefer a 1 piece for simplicity and to ditch the center bearing.
    I looked at Glen75's 2j merc setup and he has an interesting but expensive custom jobbie on the back of his 2j auto box
    The main objective is to ditch the rubber donut because of clearance issues, id prefer the easiest/cheapest alternative but dont want to make the tailshaft the weak point as it will be supporting 500ish hp. When i say easiest/cheapest i dont want to totally skimp out just dont want to go overkill.
    12.4 @ 110mph
    May 2007
    see this thread for a part number...
    http://www.toymods.org.au/forums/par...ange-only.html
    the big nut can be removed with a 30mm or 36mm deep socket i believe... and that stupid pronged thing will come out...
    you can then get your tailshaft custom 1 piece or whatever to suit what you want...
    Awsome! Now what are the chances of me finding one of the thingy's?
    12.4 @ 110mph
    May 2007
    probably pretty slim but you could try rutherford and bond toyota in nz and see what the price is...
    in that thread the price was 220 and from nz parts are usually cheaper
    call some auto gearbox mobs you never know your luck...
    opening up this discussion again.
    I think ive seen somewhere a one piece tailshaft with no slip yoke. Would a non slip yoke tailshaft be ok in a cressida being IRS rear? Im just thinking this because it would give me more room under the car for the exhaust and there being no centre bearing
    12.4 @ 110mph
    In my old auto setup there was a long slip join. Sort of like a shock absorber.
    any pics? anyone else got some thoughts?
    12.4 @ 110mph
    Dec 2008
    western australia
    i thought it needs a slip section ..you can still have one piece with slipyoke in it . hilux 4wd have a inline slip yoke tailshaft
    like this one on ebay
    Hilux 4 runner 4x4, 82-88 slip joint, minitruck, rear drive tail shaft | eBay
    awsome! cheers had no idea you could run something like that.
    12.4 @ 110mph
    Apr 2010
    queensland
    some guys swap over the 7m cressida auto extension housing on the 2j box that way you can run the factory tailsharft? i looked into it when mine was auto but i think you have to open up the auto and swap the 7m sharft. to run the slip yoke like the 1j's. mv autos have done it from what ive heard. how big of an exhaust are you going? ive got 3.5'' with center bearing with plenty of room?
  1. Setup for auto tranny Toyota A340E for drag racing?
    By CHB in forum Tech and Conversions
    Last Post: 15-10-2008, 08:36 PM
