Results 1 to 9 of 9
Thread: Ke70 mysterious brake fade
    Default Ke70 mysterious brake fade
    I have a mysterious brake fade in my corolla which im trying to find the source of the problem. When braking the pedal is hard but after a few seconds of sitting with my foot on the brake it goes to the floor
    Its a 83 ke70, the problem started before the front struts were replaced with T18 items and new front brake hoses, the master is only 2 yrs old since being rebuilt. I checked the rear wheel cylinders for leaking brake fluid. The flexible brake hose to the diff is in good condition with no cracks or visible leaks, and the fluid has been flushed and bled recently
    Im stuck on where to look next
    Can anyone tell me what would cause something like this to happen and what i han look for to fix it or even some test's to try and find the problem?
    any help appreciated
    RA23 1JZ VVTi 373hp - SOLD
    12.4 @ 110mph
    THE EVOROLLA 262.9hp - SOLD
    Default Re: Ke70 mysterious brake fade
    m/cylinder ...
    you certain? its not loosing any fluid and has been rebuilt 2 - 3 yr ago. Can they go that quickly after being rebuilt?
    12.4 @ 110mph
    Junior Member Grease Monkey Rens's Avatar
    Nov 2010
    How old is the fluid? Did you use new fluid or a container that's been in the garage for a while?
    Also, was i bled properly ? Master first, then furthest away bleed nipple next etc
    The fact its hard, then fades away while your foot is on the pedal, definitely has all the symptoms of failing master cylinder.
    Sometimes they can fail after you do a big brake bleed.. the piston goes past a point that it normally would in every day braking and gets damaged on a rusty surface.
    Now - RA23-WRX
    fluid was new, ill pull the master off get it reco'd and see how it goes. I honestly though i would have got i bit more than a couple of years out of it. oh well
    12.4 @ 110mph
    May 2010
    Moscow
    Is fluid level constant or you can note some degrading?
    Even when there's no evident leaks, fluid can still leak into intake manifold thru vacuum hose, indicating m/cyl failure.
    Tallahassee, FL USofA
    Quote Originally Posted by J0RD0 View Post
    How was the bore finish & what assembly lube?
    word back from clutch n brake place it was leaking, i couldnt even see any fluid leaking. Must have been a bit of crap in the reservoir.
    Problem solved, thanks to all who replied.
    12.4 @ 110mph
  1. Mysterious 1jz problem - ECU code 12
    By cybersimon in forum Tech and Conversions
    Last Post: 08-03-2009, 04:32 PM
  2. Mysterious Hissing device 1G-GTE
    By andyroo in forum Tech and Conversions
    Last Post: 09-10-2008, 01:32 AM
  3. Mysterious things happened on my 3TC. can any one help me?
    By CHB in forum Tech and Conversions
    Last Post: 02-05-2006, 06:00 PM
