Results 1 to 6 of 6
Thread: Power Steering Rack, Pump Overhaul - is this DIY do-able?
    Jan 2007
    Default Power Steering Rack, Pump Overhaul - is this DIY do-able?
    Would appreciated some feedback on the feasibility of overhauling a Steering Rack & Pump athome using OEM Seal Kits.
    Have been having problems with the steering on my AE111 Levin. Took the car to a Brake / Steering Workshop today and was advised that the Rack's teflon bushes have probably gone.
    The guy said that the Pump might also need attention but re-iterated that the rack was probably the culprit.
    I said that I would order the parts myself and R/R Rack & Pump and arranged to drop the units+Kits in when I got them.
    Workshop called back later - advised the guy that overhauls stuff for them would have the seals+teflon bushes in stock for rack, and all the seals for pump; quoted me $410 for rack and $275 for pump (seals only, Vane not replaced).
    The guy seemed genuine and if I could be certain the thing would be done properly with quality parts I would be happy to pay the $$$, but I'm worried that typically workshops use non-OEM seals & bushes to keep their costs down and that I would be better off doing it myself knowing Toyota Parts had been used t/out.
    How easy / difficult is it to rebuild a rack & pump? I have a garage, a good range of tools and large bench but not having taken apart a rack or pump before, am not sure if a press, etc is needed. . .
    Is it worth the hassle attempting this or are the reco units generally pretty good? What sort of warranty should I expect as a minimum?
    Default Re: Power Steering Rack, Pump Overhaul - is this DIY do-able?
    pump is a DiY affair - hardest part is removing the rear plate (if it's anything like the 3S pumps, they used an ultra-stiff wire loop to hold it in place and be really difficult at removing without stabbign yourself). Take pictures during dissasembly and then follow after replacing the seals & o-rings. Change the shaft if worn at the front seal. All metallic internals (e.g. vanes, carrier) should be OK unless it's injested lots of metal. I got a seal kit (no sjhaft) for ~$30.
    No idea about rack tho a reco+exchange unit is the easiest option. Piston part just requires suitable tools & vices. Steering shaft side could be painful if you get re-assembly wrong.
    No idea about rack warranty tho you'd expect a reco unit to come with some form of statutory warranty if sold commercially.
    Jan 2007
    Thanks. . . . appreciate the info. Think I'll just get the Rack reconditioned first & see if that fixes the problem, and do a DIY on Pump if needed.
    Jan 2008
    queensland
    pump should be asy to do as a diy
    the rack no so easy just get it recoed
    just remember that assembly is just the opposite of disassembly - just you swear in different spots!
    neil
    2009 aurion
    Purple 2000 Hilux - 1UZ
    Jan 2007
    Re. "Swear in different spots" . . That's hilarious, best phrase I've heard in a long time; really sums up the whole DIY experience. Let's face it though, we love the pain, otherwise we wouldn't be here on a Forum like this. . .
    Jan 2008
    queensland
    i might just add it to my sig then
    neil
    2009 aurion
  1. ra65 rack and pinion power steering rack
    By Intense in forum Tech and Conversions
    Last Post: 26-04-2007, 11:12 PM
  2. SW20 Power Steering Rack
    Last Post: 16-01-2007, 03:37 PM
  3. Power steering rack help
    By Johnzoku in forum Tech and Conversions
    Last Post: 23-11-2006, 12:06 AM
