Results 1 to 15 of 15
Thread: Supra Diff Spline Count
    Gorilla Industries Conversion King Koffee-Black's Avatar
    Default Supra Diff Spline Count
    Does anybody know the spline count on both the A03B and B03B diffs from the JZA80 Supra?
    I think one has 30, the other has 35???
    JZA80 Turbo Time Attack Car - "Gorilla"
    JZA80 Turbo Street Car - "Silver Back"
    Lexus RX350 F Sport "Kid Hauler"
    Vitz - Supercharged "Chimp"
    HDJ80 Landcruiser "Baboon"
    is firing on all eight. Carport Converter AndyTTR's Avatar
    Default Re: Supra Diff Spline Count
    Do you mean the number of splines on the stub axles that go into the diff housing, or the number of splines on the shaft going into the inner / outer CV's?
    Doesn't answer your question but might come in handy... copied it down while looking for diff info a while back.
    Based on info found here:
    Toyota Supra MKIV : MKIV Specifications
    and here:
    JZA80 Specifications Home
    Crown wheel
    A01 / A02 /A03: 8" (200mm)
    B03: 8.7" (220mm)
    Reduction gear ratio
    A01: 4.083
    A02: 3.769
    A03: 3.266
    B03: 3.266
    Note: USDM A03/B03 have a 3.133 ratio.
    Crown wheel teeth
    All: 49
    Note: USDM B03B / A03B have 47 teeth.
    Pinion teeth
    A01: 12
    A02: 13
    A03: 15
    B03: 15
    No. of Torsen LSD Helical gears:
    Before 1996/4
    A01B / A02B / B03B: 6
    After 1996/4
    A01B/A02B/ A03B: 8
    Oct 2011
    Finally verified so i can post. Shane what count do you need. I have a full b series conversion in the garage so ill count out what you need ? Do you need the axle into the hub count or the tailshaft count where the rear and front half join ?
    Hey thanks lads...I have no idea ay...Im ordering an aftermarket LSD, and the manufacturer has asked for the spline count. One has 30 the other 35. Im guessing the A03B being smaller would have 30?
    Oct 2011
    Ohhh he would me meaning the crown wheel then. Normally they ask 10 or 12 bolt. I will grab my b series out soon and have a quick count just to verify it for you.
    Oct 2011
    Just ready though andys post and it states there both 47 teeth. Ill crack open the diff and see if i can work out what they mean. By 30 or 35.
    I would think that info would irrelevent though as all you need is the supra lsd designed for the a series or b series lsd. When i was getting quotes for lsd's i was asked for the bolt count on the crown wheel to verify which one.
    Junior Member Backyard Mechanic manny's Avatar
    Shane, the Supra / Soarer A series centres have a 30 spline count
    GSE20 IS250 - daily
    Awesome Manny and Michael! Thanks alot for your input!
    Any updates on this lads?
    Oct 2011
    Ill check for you this arvo shane. I dug the diff out yesterday from the pile of parts in the garage.
    Champion! thanks bruv
    Quote Originally Posted by Koffee-Black View Post
    ?? I assume you want a count on the B03B as well as I already physically counted and replied above on the A03B as being 30 spline ??
    GSE20 IS250 - daily
    Yeah sorry Manny. Thanks for that. Ive got the A03B, so I am covered, but a friend has the B series. We are both ordering an ATS LSD< but they need to know this for some reason.
    Custom ****** 1st year Apprentice
    Nov 2008
    The big B diff is 35 spline
    JZA80 Supra Aerotop undergoing 3UZFE VVTi + Twin Turbos / Getrag 6 Speed conversion
    Alright! Sweet thanks Dude!!
  1. Help, 84 corona, borg warner diff how many spline 20 or 25??
    By KylJ in forum Tech and Conversions
    Last Post: 13-09-2010, 08:10 AM
  2. Spline size and diameter for MA61 DIFF
    Last Post: 22-10-2006, 05:17 PM
  3. E series diff axle spline?
    By sam-131 in forum Tech and Conversions
    Last Post: 12-10-2006, 06:07 PM
  4. help with diff axle spline ST185/205
    By terryo in forum Tech and Conversions
    Last Post: 03-10-2006, 09:14 PM
  5. W58 Supra gearbox Input spline count info
    By Esteban in forum Tech and Conversions
    Last Post: 29-12-2005, 12:11 AM
