Page 1 of 3 123 LastLast
Results 1 to 15 of 31
Thread: 1JZ MX83 breaking down in 2nd at 4500rpm FIXED
    Default 1JZ MX83 breaking down in 2nd at 4500rpm FIXED
    if i belt the car from a standstill it'll go to 6500rpm where it naturally shifts, but when it hits 4500rpm it starts to break down.
    havent tried 4500rpm in 3rd yet
    is this a common problem, plugs maybe, coils maybe
    The boobs are back
    Default Re: 1JZ MX83 breaking down in 2nd at 4500rpm
    plug gaps - but i though that was at high boost (spark blown out)?
    OT but related: life expectancy of tyres on Phil's new car? 26 days?
    have yet to turn them
    will gap plugs tomorrow night
    The boobs are back
    Equipped with Bowls Hat Backyard Mechanic Adam_Cressi's Avatar
    very interested in folowing this thread as i wanna buy a jx83.. so yeah all the lil 'bugs'
    involved i will be interested in..
    2JZ-GTE MX-83 Cressida
    Toymods Car Club Club Member # 185
    It's a long list
    Yeah check plugs and coilpacks. 0.8mm for less than 200rwkw, 0.7mm for more.
    244rwkw / 328hp @ 18psi
    is now doing it in 1st gear
    The boobs are back
    tasmania
    have you blown any fuses? may sound like a silly question, but you mighn't be getting full power...
    beer me!
    plugs more than likey, then check coils. the thing can be a faulty trigger pickup then wiring,make sure nothing has got hot extra or wires are not chaffing on a sharp edge somewere.hahaha that should give you ten minutes work for all that checked the fault codes? lol if you have the stock computer that is.
    At Work I'm A Grease Monkey Hibba's Avatar
    Question? have you got a boost gauge in this of some type?
    Also check all the vac lines for your turbo's, when i first got mine one of the t-pices had melded causing the waste gates not to open at all, so it was hitting fuel cut all the time.
    MX83 Grande
    DirtyWan Skyline GX
    how do i get the codes out of it, yes factory computer, i will check vac lines, i have a HKS FCD thats cranked all the way up, will it still hit boost cut somewhere, 20 maybe??
    The boobs are back
    update, it only does it when it hits 14/15psi,
    q's: does anyone have the wastegate/vac line diagrams
    where is the diagnosis box in a MX83
    The boobs are back
    There should be a diagnostic connector on the engine itself. Short TE1 and E1 in that and the engine light (if hooked up correctly) should flash out the codes.
    There is an additional diagnostic connector up above the driver's feet however that may not have the pin for TE1 in it. (And it may not have been hooked up in the conversion).
    HTH.
    Mos.
    jetpilot Automotive Encyclopaedia 1JZ.747's Avatar
    Quote Originally Posted by Mr DOHC
    dont have it wound all the way up, thats dangersous, have it on 9. thats what i always had mine on as did joey 321CYA back when he was twin turbo.
    8.3 et PB 169 MPH PB
    sounds like the FCD isn't doing its job properly. Boost cut is quite a violent break down, more so than a miss at those rpms because of plugs/coils etc. I have no idea about that FCD but do what shane said and report back to us Boost cut is 14.7psi stock and on stock turbos I would leave it at around 14psi max unless you like living on the wild side
    QUICKEST 1JZ'S IN OZ
    to me it sounds like its running very lean in that rev range or somethings not douing its job, i would try the setting on 9 first, if that doesnt do something, pull the thing off to eliminate its not faulty.
    like chris said boost/fuel cut is a big hit not a series of popping and farting.
  1. mx83 1jz auto issue
    By jeffro in forum Tech and Conversions
    Last Post: 16-02-2014, 09:47 PM
  2. 1jz vs 2jz heads
    Last Post: 04-05-2006, 10:07 AM
