Results 1 to 9 of 9
Thread: AE82/92/101 Corolla - front brake upgrades
    Aug 2009
    Default AE82/92/101 Corolla - front brake upgrades
    Something I have been researching has led me to this post below on Toymods by Witzl sometime ago.
    Not sure how topical it is, but I have found the need to upgrade the brakes on my spare AE92 fwd track car after fitting some new wheels. My notes are at the bottom based on my investigations and testing of some locally sourced bitz.
    Below is from the old post in 2006, I was not able to respond, so I thought I would re-post it.
    Quoted from; http://www.toymods.org.au/forums/faq...ade-guide.html
    The following is a guide that has been on the Toyota Corolla Twincam Forum forums for some time now, but it's something that answers nearly every question you could ever have about upgrading the brakes in your AE82, AE92 and possibly AE101.
    All of the information below is from Shano2's experiences mixed with mine, Singlecam's and a couple of others who have played with the brake options on these FWD corollas.
    Enjoy!
    Shano2's FWD Corolla Brake Upgrade Guide.
    Firstly NOTE the following information is for Australian models and MAY vary for US, UK and other markets. I suspect Toyota being Toyota they used the same parts worldwide but take this into account anyway and measure before you buy or fit so you don't waste time and money.
    Secondly Toyota have made it a common practice over the years to produce many interchangable parts and brakes are no exception.
    AE82
    Originally this topic was solely aimed at the AE92 as that is the model I have worked on most. Recently though I have done some work on an AE82 (singlecam's 4AGZE AE82) brake system and it's time for an update to reflect this.
    AE82 REAR
    See the proceedure below for the replacement of AE92 drums with AE92 discs. It is almost exactly the same for the AE82 EXCEPT where the AE92 demands that you replace the rear most suspension arm with the arm from disc-braked donor car the AE82 does not. All you need is the discs, calipers, hubs, uprights, handbrake cables and flexible brake lines.
    AE82 FRONT
    Exactly the same as that for AE92 below. I have now completed swapping the Superstrut twin piston calipers onto an AE82 and I can confirm that all the measurements are the same. Discs should be machined down to 262-263mm in diameter.
    AE92
    WHAT YOU'VE ALREADY GOT
    The AE92 series Corolla's came out with a couple of different brake setups depending on the year of manufacture of the car.
    1.) Ex factory the early series AE92 series Corolla's (up to 6/91 in Australia) had either :
    a.) 243mm * 13.5mm thick solid discs at the front with drums in the rear (Basically all models from the base (CS) to the higher spec (CS-X) Hatch and Seca in Australia EXCEPT for the SX as below and the "Ultima" Seca which had the solid front discs (but may also have had rear discs) OR
    b.) 238mm dia * 18mm thick vented front discs with 242mm dia * 9mm thick solid rear discs. (SX hatch and Seca in Australia also refered to as the FX and other model codes in US and other countries)
    2.) Ex factory the late series AE92 series Corolla's (From 6/91 on in Australia) had either :
    a.) 243mm * 13.5mm thick solid discs at the front with drums in the rear (Basically all models from the base (CS) to the higher spec (CS-X) Hatch and Seca in Australia EXCEPT for the SX as below and the "Ultima" Seca which had the solid front discs but may also have had rear discs) OR
    b.) 258mm dia * 22mm thick vented front discs with 242mm dia * 9mm thick solid rear discs. (GTi hatch and SX Seca in Australia also refered to as the FX and other model codes in US and other countries)
    THE most important measurement to take is the centre hole of the disc. ALL AE92 models had a 54mm centre hole!!!
    WHAT YOU CAN FIT
    So for those who want to do a brake upgrade on the AE92 series Corolla's you have the following options :
    AE92 REAR
    1.) If you have drums you can bolt on the standard AE92 rear discs, which are the same as the (Jap-spec) AE92 levin GTZ rear discs.
    To do this conversion you will need to source the follwoing parts -
    - Both rear discs
    - Both rear calipers
    - Both rear hubs / uprights
    - Both rear flexible brake lines
    - Both sides of the handbrake cable
    - Most importantly it is very important when buying the parts for this conversion (assuming it's off a wrecked SX Corolla) you will need to get the two rear most suspension arms from the wreck as the suspension bushes are different. If you cannot get these arms for whatever reason bushes can be made up to enable the hubs from the SX to be fitted to the suspension arms of the non-SX. Steve Williamson or Jason Purcell can guide you as to where to go to get this done as they have both done it themselves in Brisbane.
    NOTE however that by going from drums to discs at the back you may affect brake bias and may need to have the "crack point" of your bias valve altered (by a professional) by changing it's internal springs to suit the discs. Adjustable bias valves are illegal on the roads (at least they are in Australia).
    2.) If you already have rear discs but they're not enough you have only two options :
    a.) The AE101 has 266mm dia * 9mm thick solid rear discs BUT the centre hole of these discs is 55mm rather than the AE92's 54mm. 1mm might not sound like much but once you fit it and you have a massive vibration you'll soon realise it is. This means they'll flop around like a c0ck in a bucket as it's the centre hole that centre's the disc on the hub.
    I have now completed this conversion and found it has made a noticable difference to how well the car pulls up. I have felt for some time that the AE92 needs a little more rear bias and in my opinion it seems that Toyota went about fitting bigger rear brakes to the AE101 to achieve this rather than going about it the proper/traditional way and adjusting the bias valve in the master cylinder. It's cheating but it works.
    From here you have two methods (I did the first/easiest one):
    I.) Fit the AE101 hub in place of the AE92 hub. The is a very simple bolt on job.
    - Remove the AE92 calipers and discs.
    - Remove bearing carrier
    - Remove disc dust shield
    - Fit AE101 dust shield in place of AE92 item (fits straight on)
    - Fit AE101 bearing carrier in place on AE92 item (bolts straight on)
    - Fit AE101 disc and caliper (NOTE the AE92 hand brake cables need to be retained and will work perfectly with the AE101 calipers)
    NOTES RE STEP 2 ABOVE : The "bearing carrier" is the part that unblots from the "upright" (the big lump of cast metal that the control arms, strut and bearing carrier bolt to) by sticking a 14mm socket through the hole in the "hub" (the round part holding the four wheel studs that the disc and then wheel go over the top of) and undoing the four bolts holding it in place. It has the same mounting bolt pattern as the AE92 so the AE101 bearing carrier will bolt straight on in place of the AE92 bearing carrier.
    The reason you NEED this bit is that it gives you the 55mm centre hole needed for the AE101 discs. It also gives you the added benefit of a slight increase in track.
    These parts should be the same as the Aussie delivered AE101's so you can either buy from a wrecker who has a rear disc Aussie AE101 or buy a complete strut assembly from the time wasting, scumbag, rip off merchants at Just Jap in Kirrawee. Last time I asked they wanted $125 a side for a complete strut, upright and brakes from a Jap AE101.
    I picked mine up from a private sale for $100 for both sides and then sold off the AE101 rear struts for $50. These struts are the same as the AE92 rear SX struts which are the bigger type needed to fit Koni inserts. The short version = they're saleable.
    Bleed the brakes and your rear upgrade is finished, simple as that.
    The only other consideration in doing this conversion is that you may find the AE101 rear discs may have ABS. If it does you will find an ABS "tone wheel" on the back of the bearing carrier when you remove it. This will not allow the AE101 hub to bolt up to the AE92 upright. You can remove this by putting the hub in a vice and removing the ABS tone wheel (it may break off before it comes undone - that's ok as it's useless to you anyway) OR you could drill a 10mm hole through the centre of the tone wheel and it will fall off.
    If you insist on being difficult then you can always do it the hard way and -
    II.) It should be possible to get the centre hole machined to be larger still and then machine up a ring which is 54mm inside dia and has a matching outside dia to what you've machined your discs out to. Example - If you machine the centre hole of the AE101 disc out to say 64mm and make your ring 64mm OD and 54mm ID the ring will slot in between the hub and the centre hole of the disc to centre the disc. NOTE To do this properly the ring should be a interferance fit with the disc so there is no play and also the ring should have a taper machined into the back of it (where it sits against the hub face) as the disc does, to centre it properly.
    b.) Custom made, which = $$$$$$
    AE92 FRONT
    1.) If you have Solid front discs then you have three options :
    a.) You can simply bolt on either early series AE92 (SX) 238mm dia * 18mm thick vented discs and calipers OR
    b.) You can simply bolt on late series AE92 (SX Seca / GTi) 258mm dia * 22mm thick vented discs and calipers. OR
    NOTE : These discs share the (all important) same centre hole and disc offset. All of the AE92 (and also the later AE101 and AE111) hubs share the same caliper mounting holes, so the calipers will bolt on.
    c.) You can fit the superstrut brakes (Procedure explained below).
    NOTE : both b and c above will require slight modification to the backing plate for clearance
    2.) If you already have early series AE92 SX front brakes (238mm dia * 18mm thick vented discs). You have two options :
    a.) You can simply bolt on late series AE92 (SX Seca / GTi) 258mm dia * 22mm thick vented discs and calipers. OR
    NOTE : These discs share the (all important) same centre hole and disc offset. All of the AE92 (and also the later AE101 and AE111) hubs share the same caliper mounting holes, so the calipers should bolt on.
    b.) You can fit the superstrut brakes (Procedure explained below).
    NOTE : both a and b above will require slight modification to the backing plate for clearance
    3.) If you already have late series AE92 SX front brakes (258mm dia * 22mm thick vented discs). You have only one option :
    a.) You can fit the superstrut brakes (Procedure explained below).
    You'll need at least 14 inch Rims to fit over the late series AE92 SX brakes but 13 inch rims will fit over the early series AE92 SX brakes.
    SUPERSTRUT BRAKES
    The Superstrut brakes as available on the AE101 Levin's etc as an option in Japan have 275mm dia * 25mm thick vented discs and twin piston calipers. Fortunately they also sport the same 54mm centre hole and disc offset as the AE92 series Corolla brakes which allows them to be fitted easily to this model Corolla. The swept volume of the twin pistons is the same as the, larger, single piston in the other brake options mentioned above so these do not affect brake bias and being a twin piston design, while not as good as a proper "opposed" piston (2 pot or 4 pot) they give much better "feel" and less pedal effort. The advantages of these brakes is the thicker disc, twin piston caliper and that the caliper is mounted radially further out (can apply marginally greater braking torque).
    To fit them to the AE92 series Corolla's you do have to do a few modifications though (It's worth the effort though ). You should do the modifications in this order :
    1.) You will find that the caliper won't actually bolt straight onto the AE92 hub as the middle of the caliper hits the centre of the hub. You need to relieve a small amount of material from the caliper for clearance then the caliper will bolt straight up as the mounting bolt pattern is exactly the same. This is easy to do with a simple angle grinder and doesn't weaken the caliper at all. If you do a dummy fit of the caliper onto the hub (without the disc) you'll see exactly where the material needs to be removed anyway. There is a "ridge" in the material at the point where removal is required, grind down to this point and you'll have plenty of clearance. With this done the caliper should now be able to mount up to the hub without hitting anything. See pic below........on to step 2
    2.) You will need to find someone who can machine the disc down in DIAMETER not just the normal surface machining method. The reason for this is that the mounting point for the caliper on the AE92 hub is further in than the AE101 hub so you'll find that the inside of the caliper will foul the outer edge of the disc if you try to fit it without reducing the diameter of the disc first. In fact the caliper won't even reach it's mounting points with the disc un-machined. The most effective way to do this is to supply the brake machinist a hub, a caliper and both discs so he can machine the disc to suit the specific brakes you have. The Superstrut brakes fitted to my car were machined down to 259mm diameter but the pads sit right at the edge of the disc and given there is still plenty of clearance between the outer edge of the disc and the inner edge of the caliper I would only machine them down to 262mm if I were to do this again..
    3.) Bit's and pieces :
    - Pads for the Superstrut brakes are the same as SW20 MR2 so parts aren't a problem.
    - The AE92 flexible brake lines will bolt up to the twin piston calipers.
    - The minimum I've tried these brakes under is a 14inch wheel and they don't quite fit. You'd need either aftermarket 14's or a ~5mm or so spacer to make them fit under a 14 inch rim. They will definitely fit under 15's.
    - Disc Brakes Australia (DBA) has a disc which is basically the same as the Superstrut disc save for 3mm extra diameter (but you need to machine them down anyway).
    The part number for these discs is DBA743 and they are off the ST185 Celica. This makes them a five stud bolt pattern but this can easily be re-drilled. In fact if you order at the right time and through the right people you can get "blank" discs which are not yet drilled for stud pattern.
    COMPARISON OF BRAKE DIAMETER OF ALL THREE DISCS
    ***PIC COMING SOON***
    COMPARISON OF BRAKE THICKNESS OF ALL THREE DISCS
    Other Options
    There are two other options, both of which I've done, and both of which I don't like and wouldn't do again :
    1.) The "normal" (non-Superstrut) AE101 brakes use a 255mm dia * 22mm thick disc and use the same single piston caliper as both of the AE92 series SX brakes. The problem with these is they use a 55mm centre hole so they don't go straight onto the AE92 hubs (54mm centre hole). You can either :
    a.) Do the same as mentioned above for rear brakes by swapping the AE101 bearing and hub into the AE92 upright. AE92, AE101 and AE111 all share the same front wheel bearing. AE82 wheel bearings are a different part number but without having tried to interchange them I wouldn't be prepared to say that later bearings WON'T fit OR
    b.) Fit the AE101 hub / upright as well. To do this you'll need a tapered reaming tool (and costs about $90) with just the right taper for the AE92 ball joint as the AE101 ball joint is smaller in diameter along the length of the taper. You need to ream out the hole at the bottom of the AE101 hub to fit the AE92 ball joint into it. Then the AE101 hub will bolt on and allow easier fitment of the AE101's normal brakes. The AE92 tie rod ends will bolt straight up to the AE101 upright.
    Personally I think there's to much effort to get these brakes to work when the series 2 AE92 SX brakes will bolt straight on with no modification at all, the problem is finding a set.
    Also the pad in these brakes tends to sit right on the outer edge of the disc which I don't like.
    2.) The very first set of Superstrut's I did for a mate had stuffed discs so we found a Mitsubishi Magna disc (DBA425) which had similar thickness, diameter, offset etc but the centre hole was too big so we had a couple of rings machined up similar to the fitment of REAR AE101 brakes above and followed the rest of the modifications for the fitment of the Superstrut brakes.
    I wouldn't do this again, as was mentioned below I have since found that DBA743 can be used as a replacement disc for the factory Superstrut disc in this conversion and should be a hell of a lot cheaper than new ones from Toyota as they are $621 odd EACH!!!
    Having done a bit of searching around for some Superstrut brakes recently I went to Toyota VIN number in hand (thanks to Anthony Kellam) to get some prices from them. You never quite know with genuine Toyota parts some can be surprisingly cheap and others a complete rip off.
    The good news is Toyota can get brand new Superstrut discs and calipers here in Australia.
    The bad news is you need to be an oil Baron to afford them -
    Discs = $621.50 inc GetStuffedTax EACH!!!!!!!!! for a phucking brake disc???
    Calipers = $309.10 inc GetStuffedTax EACH!!!!!!!!! which is slightly more reasonable but expensive none the less.
    That's $1800 odd dollars and you still have to macine them down and get pads....JESUS CHRIST!!!!. $2K would be getting pretty close to the cost of custom discs and four pot calipers.
    Oh well the second hand market is alive and well
    ......rant over.
    Finally a quick note on the use of EBC brakes pads with DBA discs.......
    No I am not about to slag either off as I have used this combination and had good results. HOWEVER I have had it recommended to me by a reputable brake expert (yes a genuine one who spends some of his time addressing group tours of a brake factory to help them learn more about brakes and the rest operating his brake workshop which "specialises" in brake upgrades) that when fitting NEW EBC pads and NEW DBA discs that it is best to fit the discs initially with your old pads and let the old pads bed the new discs in before fitting the new discs. Which may well be good practice even using other products anyway.
    WITZL NOTES: EBC Greenstuff pads now come with a "bedding material" which is designed to bed the disc in before the pads, removing the need to bed a new disc with old pads. This stuff is pretty squeely and will last around 500-1000kms. Last edited by The Witzl; 20-02-2006 at 11:55 AM.
    WILLOFAN NOTES: to add to the above, I have managed to source some ZZE123 2004 Corolla Sportivo front brake rotors (discs) and calipers to come up with a worthwhile conversion for my AE92 3dr FX-GT. Looking for any feedback someone might be able to add before diving in to deep.
    The ZZE123 rotors are 275mm x 25mm vented with a 55mm centre hole. This combination fits neatly in my 16" rims and bolts up to the existing mounts.
    Will post some photos during the actual conversion.
    Rgds, Willofan
    Chiba
    Default Re: AE82/92/101 Corolla - front brake upgrades
    Or talk to Bazda for some REALLY big brakes...
    315mm rotors (IIRC) with 4 pot calipers.
    I wub my Wilwoods.
    Oct 2011
    Excellent info.
    Will look at upgrading the brakes son for my 92 Khana car.
    After playing with a Familia for a while and getting a custom Series Iv RX7 setup done, this makes more sense and seems easier.
    Might have to talk to Bazda about a setup for the GTR Familia.
    Just have to find an excuse not to let Damian drive it.
    Jul 2008
    Auckland
    Want nice big brakes - Talk to me
    Now 9AGTE 410kw atw
    Sep 2011
    I used that guide and I'm running superstrut ae101 calipers with ae101 discs and sw20 pads. Brand new bendix and it's castrol super duper dot 4 brake fluid. the silver bottle and I've had no fade, the braking is very strong and its amazing how much of an improvement it is. So if you don't want to go the whole shabang with the wilwoods the ae101 are nice.
    Jul 2008
    Auckland
    The superstrut calipers are good to a point, have been proven to work on Corollas for years.
    If your doing series racing and your car has a bit more straight line speed than a stock setup you will find the limits of them for sure.
    Bigger brakes = Less heat = less pdeal effort = pads and discs last a whole bunch longer.
    Now 9AGTE 410kw atw
    oregon
    Hmmmmm, me have an AE95 Has the vented rotors up front and the larger drums. I was able to source a "full" brake package from Project Mu
    Any word on the GT4 caliper option Baz???
    Current ride/s:
    1999 Subaru WRX
    Jul 2008
    Auckland
    Quote Originally Posted by lenjiman View Post
    Yea we can do an upgrade using brand new OEM GT4 calipers but its a little more $ as the caliper is more $ from new.
    Now 9AGTE 410kw atw
  1. Replies: 33
    Last Post: 20-05-2011, 04:25 PM
  2. Needs To Stop...RN41 *front* Brake upgrades
    By Rat_Tilly in forum Tech and Conversions
    Last Post: 23-03-2008, 01:35 PM
