Hey Baz.
Im very interested in the Tilton twinplate clutch kit including convertion kit for hydrolic throw bearing bracket & kit.
I too have a 2jzgte making 500rwkw & R154 box. can you give me a price including delivery to Sydney/ Aus a.s.a.p
PM me or call or sms me on 0414239672
please also send me payment details.
Now 9AGTE 410kw atw
hey mate you still doing the throw out bearings? im looking at buying a manual uzz30 with a w58 but the slave and fork prevents me fitting a stock exhaust.
so how much for a slave setup posted to brisbane to bolt onto w58 and r154 is possible? its a bullet bell if it makes any difference.
Yes we can provide all the parts to fit both boxes.
Its $300AUD delivered.
http://www.toymods.org.au/forums/mrp...-w58-r154.html
Now 9AGTE 410kw atw
Hey I'm currently fitting a 2jz to a vt commodore and using the t56, just checking the clutch youse do would suit? If so, how much posted to perth wa? And also do I send u the 2jz auto ring gear so youse can fit it to flywheel, or do I get that done here?
Cheers heaps!
Hey, you can fit the ring gear your self, its pretty easy. Just heat it up and it slides on.
Price on the clutch kit is $1750NZD delivered
We can provide new rings gears fitted as well for an extra $145NZD
And if you need a hydro bearing setup the new price is $320NZD as we now use the Quartermaster bearings which are more $
Now 9AGTE 410kw atw
Pricing has been changed to NZD as exchange rates are not stable and have changed over 10% over this year.
Now 9AGTE 410kw atw
Yer sweet, how much rwhp would this setup hold? And the stock t56 csc should work with the adapter plate and aristo auto bellhousing ay?
Thanks again!
Now 9AGTE 410kw atw
Ah cool! Once I finish makin dump pipe, manifold and cooler pipework, ill pull motor and box out and measure the adapter plate etc and msg ya detailsCheeers!
