Results 1 to 8 of 8
Thread: crown diffs
    Mar 2011
    Default crown diffs
    Hi can anyone tell me if the ms112 and the ms123 diffs are the same or different?
    Act
    Default Re: crown diffs
    MS112 is Live vs MS123 IRS
    Both F series,
    Not sure on the ratio's
    Mar 2011
    thanks for your answer
    Act
    is that what info you where looking for or do you need more??? Are you want to do a diff swap/ ratio swap/ Lsd???
    Mar 2011
    I want to convert my MS65 to four wheel disc and have been told that the MS112 would be the best suited for the job, any thoughts on that would be helpful.
    Im also putting in a 1UZFE to power it.
    I came accross a ms123 cheap and thought I would ask the forum the difference before i bought it.
    Act
    yeah easiest way to go discs on the rear is to run a MS112 rear end. It all bolts in. Howerver Im not sure of the diff flange have you got a borgy or a Jap diff under your car.
    With a stub axle change the fronts should go on too.
    Join the Crown thread in the general section and all us Crown boys will be able to help you out
    Mar 2011
    mine is an aussie built 1974 ms65 yeah i would like to find a ms112 diff and front brakes so it is all the same.
    Its so hard to find these parts i guess not many being dismantled these days.
    crown thread sounds good
    Act
    yeah there are getting few and far between, CLG/Clint from WA was saying that he hasn't seen one in a wreckers for a while
  1. T series diffs
    By little ra40 in forum Tech and Conversions
    Last Post: 28-08-2009, 09:28 PM
  2. Diffs?
    By Centretek in forum Engine & Driveline Conversions
    Last Post: 02-03-2008, 01:44 AM
  3. F series diffs
    By whatthe? in forum Tech and Conversions
    Last Post: 17-02-2006, 10:47 AM
  4. t series diffs
    By spoon in forum Tech and Conversions
    Last Post: 03-01-2006, 12:11 AM
