Results 1 to 3 of 3
Thread: MA61 rear suspension options for track use
    Default MA61 rear suspension options for track use
    I'm trying to decide what to do with the rear end of Badger...
    Requirements are:
    Good tunability
    Ease/availability of different spring rates
    Speed of changing springs (to swap between drift/grip setup)
    Price (ima student afterall )
    The two options I can see are:
    KYB AGX shocks
    Custom wound springs ($280 or so FFS)
    Or...EF (?) falcon springs
    Or
    S13 rear coilover assembly.
    This requires cutting and modifying the floorpan and bracing the lower mount on the swingarm. Not a terrifying job, but a bit of a PITA. (this will *not* be registered!)
    There are lots of advantages to the coilover assembly, but it is a bit rough in some ways.
    Can anyone tell me the exact spring that is usually used? EF rear comes to mind, but I'm not sure if that's right...if I know what it is I can go and research spring rates
    -RM
    Default Re: MA61 rear suspension options for track use
    What classes do you want to compete in? The S13 setup may rule you out of IPRA.
    I think it would, Takai mentioned that modifying the shock towers would rule it out...
    It's mostly for autokhana, speed event series etc, stuff that doesn't follow heavy guidelines, as long as the car passes scrutineering...
    -RM
  1. S13 suspension (front and rear) into MZ11/Ma61 *LCA'S???*
    By Johnzoku in forum Tech and Conversions
    Last Post: 13-07-2009, 01:40 AM
  2. Ma61 rear arms into Z10 for less track
    Last Post: 04-11-2008, 08:38 PM
