Yeah... a BPV was on my original list, and I wanted to use one of those "mini-style" servo operated butterfly valves. Only problem was I couldn't find a place to fit it in at the design stage, so I left it out. Along the way I picked up the Bosch valve as it had smaller connections. Once the inlet ducting was up and running, I figured out a way to fit it in... tight squeeze
For the Air Temp enrichment I have settled on zero compensation from 35 to 60 deg. Above and below that normal compensation applies. Just trying to eliminate one variable in the operating temp zone (ambient to 60deg) for the charger at the moment. May have to zero it to 70deg when I start pushing the pedal a bit harder. After that the W.I. syatem should keep the temp down.
Cheers... jondee86
