Results 1 to 10 of 10
Thread: Sway Bar for 1GZFE RA23?
    Toyota for life REP! Backyard Mechanic TTV8RA23's Avatar
    Jun 2006
    Whakatane
    Default Sway Bar for 1GZFE RA23?
    Im after a good heavy sway bar with a hump in the front to get around the front sump setup. I have heard AE86 ones are a good option. If anyone has a heavy aftermarket AE86 one can the measure for me how far out the bulge in the sway bar is(A) and how wide it is (B)
    Uploaded with ImageShack.us
    Any help would be really appreciated.
    Failing this does anyone know of a company that makes decent custom ones?
    Simon
    Kiwi back yard mechanic/fabricator/machinist/welder
    http://www.toymods.net/forums/showth...t=tt1uzfe+RA23]
    Jun 2006
    Whakatane
    Default Re: Sway Bar for 1GZFE RA23?
    Noone know? Must be an AE86 owner out there than can measure up his/her Sway bar for me?
    Simon
    New Zealand
    There are some measurements for a custom KE70 one here -
    DX corolla KE70 custom front sway bar | Trade Me
    I don't think it sold and was used with a 1G-GTE so could be suitable for you. Advert also says it was made by Chamberlains in Christchurch so worth contacting them too.
    Callum
    Jun 2006
    Whakatane
    Thanks Callum i will contact them!
    Simon
    Wgtn
    Also have a look at a E36 BMW ('90s 3 series) front sway bar...
    The top one:
    How about a picture of an ae68 bar in an RA2X.
    Man the underside of it looks dirty :S
    stidnam
    Jun 2006
    Whakatane
    Thats what im after stidnam. Can you please take the measurements i have asked for so i can see if this will clear the 1gz sump. Even just measure how far it steps forward for me cos the width looks more than adequate!
    Cheers Guys
    Simon
    New Zealand
    Talk to Sheepers as well, think his bar was custom but based off an AE86 one?
    Callum
    That step forward from the inner most point of the front, measured down the angle to the outer point of where it makes the bend is approximately 100mm. I took a rough measurement of it on the weekend when I saw the car, after remembering this thread. Just rough though!!
    Either way you should be able to use it along with the picture showing where the bar is in relation to the castor rod bracket.
    Keep in mind that the the forward in the bar angles down when the wheels are on the ground. I'll look for a picture from the side to show where the bar sits height wise. Not sure if I have one though.
    No such luck. Got no pictures from the side.
  1. RA23 Sway bar width
    By The GW in forum Tech and Conversions
    Last Post: 18-01-2011, 02:03 PM
