Results 1 to 6 of 6
Thread: how to determine which 20v head?
    Nov 2010
    tasmania
    Default how to determine which 20v head?
    hey guys,
    just looking for how i go about confirming that i have in fact got a blacktop head?
    any wonderful clues from those in the know?
    pat
    oregon
    Default Re: how to determine which 20v head?
    the blacktop head has almost no squish area, the only area with a squish area is along the exhaust valves. the silvertop has squish small areas along the exhaust as the blacktop does, but it also has small areas between the intake valves as well
    Blacktop is on left, silvertop is on right
    also on the exhaust side i think it is, there are a lot more casting ribs on the silvertop head compared to the blacktop. ie. ribs closer together and more of them.
    Fantapants - can you throw up a quick photo of the combustion chambers and exhaust side of the head? we should be able to give you clear indication then as to what head it is exactly (silvertop or blacktop).
    here you go Pat:
    SQ Engineering - Articles - 20V differences
    or just post some pictures on here
    Nov 2010
    tasmania
    head is off at the moment trying to be ressurected :s
    if its repairable, then ill get it back and get pics... if its not, ill just cut my losses and practice my porting :S
  1. RE: E58 LSD's - Definitive way to determine if LSD or not?
    By PooJou in forum Tech and Conversions
    Last Post: 20-08-2008, 10:42 PM
  2. 20V silvertop head on gze bottom end - head gasket thickness?
    By RT40Corona4AGTE in forum Tech and Conversions
    Last Post: 13-01-2008, 02:15 PM
  3. Cylinder head corrosion, time for new head or should it be ok?
    Last Post: 05-06-2007, 04:38 PM
  4. ARP Fixings - How do I determine what I'll need?
    Last Post: 27-05-2007, 02:55 PM
