Results 1 to 15 of 25
Thread: 2azfe crank in 3sgte
    Junior Member Grease Monkey off-road's Avatar
    NT
    Default 2azfe crank in 3sgte
    Does a 2azfe crank fit in a 3sgte?
    jimmya Grease Monkey jimmy_a's Avatar
    Default Re: 2azfe crank in 3sgte
    I'd hazard a guess that it doesn't.
    Being different engine series and the fact that the stroke on the 2az is longer id say youd have trouble and thats not even taking into account bearing sizes or the piston separation or anything.
    Classic Not Plastic Domestic Engineer ace's Avatar
    Quote Originally Posted by jimmy_a
    Good work on answering him, i didn't think it was worth it.
    My TA22
    Quote Originally Posted by gianttomato about new cars
    Yeah sure, it goes alright and it's got air conditioning, cup holders and automatic tampon removers, but where's the charm?
    Western Aus
    thats like asking if a nissan ca18 crank fits the 4a...
    Eldar.O.
    you might be surprised
    start by checking the bore spacing.. if that is different, you have no chance.. at all...
    2AZ bore = 88.5, 3S bore = 86,
    2AZ has 10mm more stroke (5mm each way)
    given that the newer 2AZ motor probably has thinner bore walls... it might be close....
    find headgaskets, compare
    find bearing sizes, compare
    (if bigger they could be turned down, if smaller.. custom rods, if mains are smaller... forget it)
    find two cranks, measure em up...
    or it could be a stupid idea
    Ace and Eldaro, if it does work, you're gonna look silly at least it'S something new to try (until it doesn't work )
    edit:.. but yes.. chances are slim .. but stranger conversions have been done before
    Eldar.O.
    or if a ford 250 crank fits in a holden red motor... oh, hang on a minute... lolzor @ u!!!oneone
    Alright say it did fit in the 3sgte, what would the advantages be?
    My TA22
    10mm more stroke sounds like the "advantage". You'd get about 12% more capacity once the engine is built to suit.
    Rosewood
    but wouldn't the 5sfe crank be an easier swap? although only a 10% increase in capacity.
    It sure would be. you won't get as much stroke but you know it fits in the block.
    New Zealand
    The 4Y crank is not an uncommon swap into a 3T block, clearancing/mods required though. Have even seen picks of a 2TG head on a Y block.
    Callum
    Quote Originally Posted by WDE_BDY
    Callum
    concur
    ten characters
    Western Aus
    Quote Originally Posted by SeptemberSquall
    bahahah, that has what to do with what i said?!
    nissan and toyota are completely different to holden and ford, as holden and ford seem to be lagging 6 decades behind any japanese company to date.
    even so, ford and holden have both gone in the same direction with their products, similar technology, nissan and toyota, well, i think they speak for themselves.
    so no, no lolzor at me.
    Eldar.O.
    i think he is saying the for crank fits into the holden motor
    which i think is exactly the same as nissan Vs toyota
    KE38 - 2TG
    MS65 - 1UZ
    Quote Originally Posted by emp?
    10 points
    double lolzor @ u eldar.zero
  1. bigport crank in a gze
    By AE101LEV in forum Tech and Conversions
    Last Post: 07-04-2006, 10:15 AM
  2. To 3sgte or not to 3sgte
    By General_Bupkiss in forum Tech and Conversions
    Last Post: 23-03-2006, 04:23 PM
  3. 3sgte and 4agze standard weights?
    By Taxi>Maxi in forum Tech and Conversions
    Last Post: 20-03-2006, 06:55 AM
  4. 3sgze Vs 3sgte
    By NeoNasty in forum Tech and Conversions
    Last Post: 18-02-2006, 03:03 PM
  5. 3sge - 3sgte CAS - interchangable?
    Last Post: 20-12-2005, 08:15 PM
