Results 1 to 15 of 22
Thread: MA70 Turbo A ECU pinouts
    Default MA70 Turbo A ECU pinouts
    Anyone got em?
    I know they'll be 99% the same as the other grey plug 7MGTE ecu's, but the whole, AFM vs MAP sensor I don't know.
    Is a Self Employed Grease Monkey wombat's Avatar
    Default Re: MA70 Turbo A ECU pinouts
    go to this site
    http://www.cygnusx1.net/Supra/techtips.aspx
    this has the technical serive manual online in full. and also wiring diagrams and parts cat.
    have a look around and you'll find it.
    great website
    The Turbo A is Japanese only, and to the best of my knowledge the cygnus site only has USDM manuals on it.
    fair enough. thought I'd give it a shot.
    might have it. but yeah I'm a new MA70 owner, so just learning
    vic
    AFM vs MAP there all AFM from my memory.
    Dave
    Junior Member Grease Monkey Jasper's Avatar
    I should have access to an archived photo tomorrow that will reveal all...
    Western Aus
    Quote Originally Posted by cambelt1
    Dave
    Turbo A MA70's were MAP sensored.
    only 500 7MGTE's ever were (from factory), and they came in those cars.
    Elmo.
    Quote Originally Posted by Jasper
    Thanks for that Jasper, just thought I'd give the ol' Toymods a try just in case.
    The Apexi SAFC manual has pinouts for MAP, knock, revs and power if that's all you need to know... Diagram 5a IIRC
    All I need are pinouts for the MAP.
    I'd put money on everything else being the same as the later gen 7MGTE's (scary though).
    I'll look up the manual now.
    Looks like only 1 wire is different.
    The KV setup uses a KS pin for the KV output, where as the TurboA would use a PIM pin below the KS pin for the MAP output.
    Fuck I'm good
    T5-a
    If only I could read the word under Throttle Signal???Pressure Signal
    Sheesh, dont want much do ya
    Unfortunately its the only one there with both AFM and MAP on the one diagram...
  1. twincharging prototypes needing constructive critisism (SC14 + turbo)
    Last Post: 11-10-2014, 12:02 AM
  2. Tips for my high comp turbo gen 3 3sge
    By trd3sg in forum Tech and Conversions
    Last Post: 26-02-2008, 12:43 PM
  3. What Is Involved in Going Turbo Blacktop?
    By Trekka273 in forum Tech and Conversions
    Last Post: 25-03-2007, 10:21 PM
  4. 4agze afm+cas w/ std ECU turbo conversion, anyone done it?
    By Necros in forum Tech and Conversions
    Last Post: 28-01-2007, 06:39 PM
  5. Turbo maps - a quick guide
    By -==L=a=N=c=E==- in forum Tech and Conversions
    Last Post: 21-08-2006, 01:10 PM
