To be frank I might take a rain-check on putting on the ITB's until I have researched this a bit more. There is too much I just don't know and too much (sometimes conflicting) information I need to analyse. I.e. I went and had the AE101 Fuel Pipe Rail (Part # 23801‑16061) re-plated; but didn't realise you can't mount them on T3; etc, etc
Another issue is whether the "Eagle" vacuum Chamber I got off T3 will give sufficient vacuum for the MAP sensor; there doesn't seem to be consensus on one tried / tested method / layout, i.e;
i. Drill & tap 4 extra offset holes in T3 Adaptor; this was originally proposed by a guy called "Matty" over 4 years ago (good thread but pictures long gone).
ii. Another suggested opening up existing holes to 5mm, and inserting larger barbs
iii. Another suggested using restrictors in the vacuum lines between the outlets
iv. Another suggested using just one after the outlets / before the chamber
v. bla bla etc etc.
Do any of these suggestions factor in the Vacuum reservoir? I don't know. . .
The other / related reason is of course money. I am just now
starting to realise the extent of the additional expense involved in "Quad-ding" a 16V compared with just putting in a 20V 1/2 cut. . . I'm not sure if $600 (Adaptronic) ECU I was banking on will come through and I'm stuffed if I'm going to pay $1500-2000 on top of everything else to buy a new one and have it tuned. I think I'll just hang tight and put a running watch on eBay.
Hopefully once I've got the 4W 02 connected there will be enough feedback for the 86kW ECU to run the thing half decently without getting 10MPG and rooting the Sensor & CAT (please advise if otherwise). . . Further to the above; looking at your post Jondee I googled WBO2 Gauge (first I'd heard of it) and the related info seems to suggest it needs to be used in conjunction with a Wide Band 02 sensor
. . . as opposed to 4W I was just about to purchase
It's not just the money; like most people the main reason I'm on these Forums is to ask (sometimes stupid) questions; push my boundaries and hopefully get the satisfaction of doing it myself. . .there's no way I could afford to modify & run a 2nd vehicle for Track work if I'm running to a Tuner all the time.
Anyway, thanks again everyone for your input. Hopefully my Noob questions are helping someone else out there
