Can't seam to edit from the iPhone, so I just wanted to add I suspect that this isn't directly a result of the wheel alignment, maybe it helped it surface, maye it's just a coincidence. maybe not?
Hey,
So after getting the Aristo back from a wheel alignment the car has started to feel very 'floaty' on the road. It's booked in to get the front end looked at by the douches that did it tomorrow morning, but I have a feeling that it isn't a stuff up in the front end.
Basically on road when you hit a bump or jolt, it feels like the rear end slops, slips or jumps to one side or the other. Hard to explain, but think of it like two planks on a ball, bottom planks being the wheels the top the car. Or say the camber bolts were loose and the suspension is slipping from side to side.
Does this ring any bells?
I've heard of quite a few aristo replacing rear subframe bushes, is what I've described a symptom of this?
The aristo is a daily so I've been barred from playing with it any more the required, so I'm not as familiar with it. But assuming that it isn't fixed, I'll be jacking the rear up to check over it tomorrow afternoon. I've already had an extremely quick look over the front but didn't notice any thing out of the ordinary.
So is there anything you guys can think of that I should definitely check? Etc?
Turns out the dicks at the tyre shop didnt drop the car down and then tighten. So the 'Alignment' was completely fkd. Awesome. And to think I thought that that couldn't be the problem because they're 'professionals' lesson learnt.![]()
I was going to suggest a massive alignment issue but you beat me to it. Rear toe would do this 3 degrees plus i reckon
Jim dandy
Lol Jim dandy? wtf?
1gjet, You win! I loose, turns out you can't trust the 'professionals' to even do basic shit rightStill pissed they could fk it up so bad. Feel like I should name and shame! but musn't provoke the tamed racing mods! Thanks for you help btw. No sarcasm intended.
