Gearbox will be fine, I have some mechanical sympathy and don't flatchange the C series box. Bill's held up to 240kw atw and only stripped 3rd gear once.
Thats a very very nice conversion youve got happening there.
Should be rather quick with the turbo bolted on.
Any idea how well the gearbox will take the extra power?
Daily: Toyota '05 Rav4 Sport
your a mad man jplove ya work.
Just read through the whole thread - thanks for posting so many details and pics.
It's great!
more stuff arrived, progress should be faster now.
Laser cutting order all done, got a heap of 2zz exhaust, T25 turbine inlet and exhaust, cluster bezel and 2jz flanges cut, also reveived another shipment from MWR with bosch 525cc injectors and a waterpump.
WOW ! Brilliant conversion thus far....
More pics...
Bezel and Gauges sittiing in cluster face:
Bosch Combo 3bar Map/Intake Air Temp sensor and NGK AFX Wideband:
Turbo position in bay:
Made a start on the manifold runners on Friday night, then got distracted with some JZX90 fabrication over the weekend, will hopefully have the JZX90 finished by this weekend (Custom AC, Cooler mounts/pipes/exhaust) and get stuck back into the AE82...
Have recessed the runners 4mm into the flange which will make porting from oval to round easier:
And a pic of the JZX90 with Excel AC condensor and 100mm thick cooler mounted:
Sweet work, Jason. Are you going to track it or let Mark take it for a swim?
hahah, he'll never live that one down
I think I'll be the only one tracking this at QR and Lakeside
good luck with your torque steer![]()
have got most of the turbo manifold sorted now, just a couple more welds to go then it's ready for facing, porting and coating.
This is epic .. Love to see some mounts mass produced for this to take it to the K20A honda swappers
I love my 4age FXGT Ae82but hell - 2zz power , LSD , and a turbo - OMG front wheel fun!
Saphira - ST205 Celica GT-FOUR Group A NZ No:1/4"Mongrel Garage - back on Aussie soil! "
Manifold's fully welded and ported now, got a couple of tight spots finished off by Craig at Extreme Custom Engineering in Archerfield as I couldn't get my standard tig torch in to weld it properly.... next purchase will be a weldcraft WP-50 micro torch
Also made a start on the radiator, using an AE101 china radiator custom-mounted with the inlet and outlet relocated. Undecided on what thermofans I'll be using but probably a set of WRX fans with integral shrouds. I've got the radiator mounted as far forward as possible. Lower mounts still require gussets etc to be welded in
I just read the entire thread, some really nice fabrication going on there.
Im a big fan of the 2zz, should go well in this, especially with the wizzer. It sits so much further forward in the engine bay then in the celicas.
