http://bahamutcars.free.fr/workshop/IS_98-05/index.html
This link was in a thread that you posted in and while each section is a separate pdf, it should be of some help![]()
Does anyone have the scans for the 6 speed from the Altezza factory service manual? If someone has the FSM could you scan (pdf, or anything really) the manual transmission section.
PLEASE
try serach s15, i found a manual for one of these online at some stage, but cant dig it up right now,
I have the IS300 manual, and I checked it first... but since the IS is the larger engine(not the BEAMS) it only shows W series gearbox.... I also BELIEVE that the GXE10 uses the same gearbox...
I have the S15 manual with that section, thank you for that recommendation, I'm trying to track down the other manuals as well... the Miata and RX8 versions too - Y16M-D.... because LEEN LEEN Gearbox Conversions | LEEN SXE10 Adaptor | AE86 4AGE is hoping to see what, if any, the differences are to make their adapter fit as many of the AZ6 variants as possible
I imported a Mazda gearbox repair manual, but unfortunately it didnt cover the 6 speed. Would be keen to get a copy of the mazda ones if you find them.
i have the S15 ESM but its on cd, probably a bit big to post up
Never late in an x8
All IS200 and RS200 had the J160, with obviously a different bellhousing to suit either the 1G and 3S.
I've managed to get a copy of the Mazda Y16M-D (Mazda's version of the AZ6) overhaul manual. If not someone in this group, is there another group that may have the J160 overhaul section available?????
DOH... apologies to "big zop" the needed repair section is indeed in there..... THANK YOU. I had thought it was the Lexus IS300 manual from the USA model which uses the W58, I didn't look @ the link and ASSUMED it was the same as what I had. my apologies for not being thourough
You rock, big_zop!!
Will be useful later when I pull apart one of my J160s.
For anyone reading this thread in future, I have an original SXE10 manual.
Only problem, it's in Japanese.![]()
Casey
Akaoni - My Red TA22 - BEAMS Blacktop (On the Backburner)
Slick - Wife's Blue RA28 - BEAMS Blacktop (In Progress)
Betty - White Hilux Daily - Stock Awesomeness
Dot - Black Kluger Kiddy Wagon - Stock and Soccer-Mum-tastic
Canberra Celica Group - http://canberracelica.org/
For those who want their own copy in pdf format.... LEEN Gearbox Conversions | 6 Speed Gearbox Service manual
