Do you and your mate both have the same types of diff's?
Im pretty sure rt104's came with the option of a t series diff (jap) and also a borg warner diff (aus).
If yours is a t-series then it wont have a removable backing plate (inspection plate). (banjo vs salisbury style diffs)
The point im trying to get at is i think the borg warner diffs come with swaybars, but i haven't seen an rt104 t series with a swaybar before.
1.either cut mounts and take the swaybar off a ke70 corolla sedan.
2. put a corona borg warner diff from the wreckers in with its swaybar.
3. contact whiteline and get a bolt-on (u-bolt style) swaybar for a ke70 panelvan (leaf rearend. s series) BUT the U-bolts that bolt the swaybar to the diff housing may not be thick enough. (s series housing is about 5-10mm thinner in O.D than an T series so you may run into a problem there unless you can mod it to suit. (grind housing, new u bolts or heat the supplied u-bolts and bend them to suit)
4.Hope i haven't confused you too much!![]()
