80 mm across and 60 mm deep,this is for the brake booster.
squeak
hi there
i would lik to kno the bolt pattern that is needed to bolt the standard master cylinder to the firewall
from centre to centre measurements if possible
thank you
squeak
the measurement for the master cylinder holes are also 80mm from centre hole to centre hole.
thats to bolt the master to the brake booster.
just to be sure could you ilustrate the measurements on a diagram
a rough one on lik paint is sufficient
thanks for the info so far
