Ok so i have dont a fair amount of reasearch, what i seem to have found so far is that the power fc's run a 1j fine so long as they are manual and out of a soarer. Can anyone say they are using a power fc to run a 1j from a jzx81, plugged straight in and had no problems?
Also does a power fc plug straight into any loom, ie does it matter if the car was originally automatic?
Thanks for you help
If money is the root of all evil.... then why do they pass the collection plate around in church
ah shit thanks mate
hey man, havent seen you around in a while. Still play lfs? :-P
Originally Posted by Cow Cow
Bumping up old and off stoic thread for this question.I need help asap as car is getting tuned tonight,
My tuner seems to think that my jza70 power fc on my jzx81 cannot be tuned with q laptop hand controller only.
Can someone point me in the right direction as to what he needs to buy to make his software work for this specific ecu
He tunes power fc all the time, Nissan mostly but can't get the lap top to communicate with my ecu
Thanks in advance
Most tuners use the FC Datalogit to tune the power fc via a laptop.
If your tuner has the same unit as in the link below then he can tune it.
FC Datalogit - Tuning Software for your APEXi Power FC
try to avoid tuning with the hand controller at all costs.
JZA70|R / 12.45 @ 111 mph.
Know where I
Cam get it like overnight?
Thanks heaps
Check the website for any local distributors.
BTW your english is awesome.
Thanks for your help man, sorry about writing been doing it all on I phone at work behind boss's back lol
Next question
Lost a few check lights they are doing funny things, I'm guessing it's an ecu issue being that the ecu is actually for a jza70?
Car isn't Charging no batt light on dash but comes on ok when you earth the light pin (along with cat temp and brake light warning lol). The alternator also tested fine
the charge light is wired threw the body loom not the engine loom, so ecu change shouldn't effect it?
when you say the alternator tested fine you mean bench test or its is actually charging just no light comes on?
double post
They usually do ay way is this weird shit happening lol
I'll sus it
all error codes, or should I say engine sensor activity can be viewed through the hand controller. injector duty cycle warning and engine knock CEL notifications are still relayed through the original check engine light. They just flash in different frequencies.
Ok this one has me stumped
I've lost ignition at the diag plug pin, at the alternator ign pin, but car starts n runs so getting it everywhere else
All fuses check ok,
Sounds like There is a wiring some where that not connected properly/wrong.
-Sleeper 2J + R154 X83
-GQ 93 Mav, 4.2 Diesel, 35" BFG KM2's, 4" lift, 3" Exhaust, Front Locked, Rear shimmed, Sliders, IPF foggies, UHF, 2871R and Intercooled.
