Results 1 to 3 of 3
Thread: 18rg problem
    Jun 2011
    jylland
    Default 18rg problem
    Hope someone can help !!!
    I have a ra28 from 1977, it had the 18r as standard, i converted it to a late model 18rg(head nr 88270, and solex carbs)
    It has lunenition optronic ignition (came with eletronic ignition but parts where missing)
    The problem is that it runs unstable when i drive at constant speed but not when acclerating and when it hits 5000rpm it sounds weird, (like when you pull a cats tail)
    I used the sump and pickup from the 18r and the oilpresure is great, it dosend get hot and it dosend mix oil and water.
    I have tried with new sparkplugs, leads, rotor, distributer and fuel filter.
    Am i using the wrong oil ?, i was recommended a classic oil 20w-50.
    Or do i need to rebuilt the carbs/engine ?
    Default Re: 18rg problem
    Sounds much like a carb problem, air,vacuum leak. The reason it runs fine on acceleration is that it is probably putting plenty of fuel in on that mode but on cruise it is running a little lean.
    Cheers Dave
    1977 RA28
    1972 TA22
    1984 Supra
    Feb 2010
    south australia
    Did you diagnose the problem buddy?
    By pulling a cats tail do you mean it has a fan belt whistle sound? like squeeling? My 18rg has a similar problem. (its not the fan belt; i haven't spent time on my problem).
  1. ABS problem
    By Timmie in forum Tech and Conversions
    Last Post: 12-11-2008, 02:03 PM
  2. 7mgte ideling problem and pressure problem
    By HAIRY_APES_22'S in forum Tech and Conversions
    Last Post: 25-05-2008, 05:43 PM
  3. 18rg Fuel and engine missing problem
    By Seedy Al in forum Tech and Conversions
    Last Post: 02-02-2008, 01:51 PM
