i HATE working on these at work. we call these "old" cars when they come in.
- check the IAC, they get pretty blocked up and make them run a bit crappy.
- crank angle sensors are also a common fault, but this would cut the car out when its hot.
- leaking injectors, which would cause it to flood. the fix is to hold the pedal to the floor to start (this tells the ECU its in flood mode)
If you were in SA, i would say just cruise down to my work and i would check teh codes for you with tech 1. if you can try to get the trouble code to flash up then i can check it at work in teh manual for you......
