Results 1 to 7 of 7
Thread: C52 / C56 Swap: Mounting AE111 Driveshaft Bearing Bracket onto Bigport Block
    Jan 2007
    Default C52 / C56 Swap: Mounting AE111 Driveshaft Bearing Bracket onto Bigport Block
    On inserting the RHS shaft into the C56 / LSD box, I noticed that my Bigport Block did not have a hole threaded for the upper hole of the Driveshaft support Bearing Bracket; so I just fastened it via the two (M10 / M8) threaded holes on the bottom edge of the Block.
    I know I'm not the first to have come accross this; is this safe L/T; especially if the car is run hard / raced?
    PS: The Hub side of the Bracket does not sit flush with the mounting surface on the Block so the bolt is basically trying to twist the bracket when tightened (@ per the A/C Bracket) - what's the go with this layout?? Seems wierd to me.
    Jan 2007
    Default Re: C52 / C56 Swap: Mounting AE111 Driveshaft Bearing Bracket onto Bigport Block
    Hmmm. . . so I guess I'm the only guy out there who's stuffed an LSD C56 into an AE92???
    Anyway, just to be on the safe side I'd like to drill & tap this hole; thing is I can't get my (285mm long) Bosch into area between block & firewall.
    I'd rather not go & spend $300+ on a Cordless drill with dia 10mm (Steel) capacity just for one damn hole - any suggestions as to how I might get around this most welcome. .
    Aug 2009
    i highly doubt its gunna come loose or give you drama with only 2 bolts.. i cant answer for the big port block so i dunno why the hole isnt there.. is there a space to actually drill/tap a thread there?..
    Jan 2007
    I doubt it as well; but I want to Track the thing occassionally and would rather not have the question in my mind. . .
    Yeah, there's heaps of meat there - Bracket hole centres on a raised boss sitting on a 25mm high rib - I only need to tap about 15mm of thread so max hole depth ~ 18mm.
    Coates Hire do Cordless drills @ $25/4 hrs that should fit the bill; all I need to do know is find a short M10 drill bit. . .
    Aug 2009
    dont find a short one, chop a long one haha
    Jan 2007
    All done. Ended up buying a 90Deg attachment for my drill @ Total Tools; didn't even know those things existed. Quite chuffed actually I can see myself using that sucker quite a bit.
    Aug 2009
    ahh yeah shit i totally forgot about the 90deg attachment.. good thinking with that one!
  1. Replies: 5
    Last Post: 07-07-2011, 08:26 PM
  2. Replies: 3
    Last Post: 31-07-2006, 09:15 PM
