Results 1 to 9 of 9
Thread: TA22 Five Stud Conversion
    Aug 2008
    Down
    Default TA22 Five Stud Conversion
    Evening. Has anyone redrilled the hubs of a TA22 to make 5 stud? Is it difficult? Any pics of proper procedures would be appreciated.Thanking you in advance.
    May 2011
    Default Re: TA22 Five Stud Conversion
    wouldn't you be better off going for different hubs/front end?
    I think it would be a little dificualt to redrill ta22 hubs because of how they are set up with the disk bolted to the hub.
    GOT: Suzuki SV650 with lots of mods - Almost stock XC falcon ute with 351 and gas
    Building: TA22 with SR20DET
    Quote Originally Posted by sauceman View Post
    It can't be done. The TA22 hubs only have 4 equally spaced flat surfaces where the back of the stud sits. Then you've also got the mounting surface for the disc which is not on the same plane.
    If you wish to go 5 stud it's a matter of actually changing the hubs (maybe to some from a crown?).
    You would need to upgrade the strut before you could go crown hubs.
    i know someone with ms65 hubs they want to get rid off too.
    Aug 2008
    Down
    Thanks for your thoughts. Crown bits aren't available where I live, but maybe Cuzzo could let me know more about his mates parts. I would have tried to redrill after welding up original stud holes, but you have talked me out of it at the moment.
    Aug 2008
    Down
    Had a look and you are right LeeRoy. The pits. Ae86 hubs are the same. I'm sure there is a way.Hammer time.
    RA60/XT130/RA40 and MS65 all share the same bearing. (aswell as HQ)
    Therefore you can put a 5 stud (MS65 Hub) on the above strut. (in combination with a brake setup)
    om nom nom Backyard Mechanic CheeseBiscuits's Avatar
    Yeah Ms65 hubs are the go with rt132 or XT130, or a similar strut that shares the same bearing as Cuzbro said.
    Then a hilux rear end gives you the same pattern on the rear. ^_^
    highly underrated Backyard Mechanic
    Feb 2010
    woot! this means i can convert the rt104 to 5 stud if i wish.
    good to know
    RT104 with 4AGTE
    Some assembly required
  1. 5 Stud conversion
    By red rolla in forum Tech and Conversions
    Last Post: 20-08-2008, 08:26 PM
  2. 5 stud conversion to AE92
    By 92-GTI in forum Tech and Conversions
    Last Post: 25-02-2007, 12:17 PM
  3. 5 Stud Conversion on RT142?
    By Adash=P in forum Tech and Conversions
    Last Post: 29-12-2006, 01:37 AM
